Squishy Brakes
Squishy Brakes
With roughly 64k miles on her, I had my first real dry-pavement emergency stop yesterday. I was approaching an intersection at around 45 MPH, green light, and a girl on a bike came flying out across traffic (obviously she was in the wrong, ignoring the red crossing signal), and I braked hard to avoid having to clean her off my hood. Tires held well, but I really felt like the brakes didn't grab as hard as they should have/could have.
Luckily, she stopped before entering my lane, or I would have hit her, albeit softly.
Most of my miles have been highway, and the pads/rotors have plenty of life left in them.
Anyone else notice anything similar? I'm thinking some stainless steel brake lines might be in order shortly...
You've saved her life or at least from "any" injuries.
I've not noticed anything like that nor has my wife.
However, we haven't had any situations occur that required us to slam our brakes... (Hopefully, we never do.)
I'd say check your brake fluid level.. And, get your pad(S) replaced - Even if they "look" like they have some meat left. Cause at 60K+, it's worth the little investment since it's just old factory pads.
>> I'm sure steel lines are very nice, but I'd go with a New set of Pads & Upgraded Rotors first Before I shell out extra dollars for pretty re-enforced hoses... Just my 2 cents.
How about these? food for thought.
Chrome Brakes® - Drilled and Slotted Rotors
LINK
and
Monroe® - ProSolution™ Ceramic Brake Pads
LINK
Having done a "ghetto BBK" on my Audi A4 USP (Swapped in OEM S4 calipers, larger rotors, and performance pads) and later added SS lines, let me just tell you that you'd be AMAZED at how much SS lines can do to brakes.
When you brake hard, the fluid pressure causes the OEM rubber hydraulic lines to flex and swell, reducing the pressure applied at the caliper. SS lines don't flex nearly at all, and you get a MUCH more solid pedal.
To clarify, I'm not arguing the elephant in the room (60k = new pads/rotors), I'm just saying if anyone is looking for a great way to improve braking performance without dropping big $$$$ on a Brembo BBK, SS lines can be had for a couple hundred dollars and are well worth the price.
Alright.. I hear you on those.
So, might it be Mitsu's anti-lock brake system kicking in... that made it felt - "squishy"??
I'm around 55K+ now and my brake pads are down to the shims.
Time to replace them but I'm debating on if I should get new rotors, or get the old ones turned.
Anyone have suggestions on what brand of pads or rotor+pads combos that I should look at or consider?
And, yes I'm now noticing the brakes being a tad squishy...
julian9019
Aug 23, 2016 07:33 AM
