Transmission failure..
I'm now starting to get concerned about my transmission.
I'm at 39K now with my 2015 and when I'm driving at a steady speed I notice the car will "jump" forward in RPM's.
For example I'll be on the highway cruising and then my RPM gauge will just suddenly throttle up like 500rpms on its own.
I also just found this.....
http://www.autoblog.com/2016/08/15/2...-sport-recall/
Now, in my last service which was about 3 weeks ago they did update my CVT control unit with the latest software.
This is the second update that they have done since i have had my vehicle and I'm really not liking all of these issues that I have been having.
Yes, my gas mileage seemed to improve a little and from a standstill the RVR did respond better.
It's just now after that I have the weird RPM lunging when driving at a constant speed.
It doesn't happen all the time, but its definitely noticeable.
I know you've done the recall update for the 2015 which is good, but have you changed the trans fluid and filter yet?? or when was the last time you did it
yes there are 2 filters, the one which is inside the trans pan apparently doesn't need to be changed until 100k, but there is another filter that is under the battery tray that is part of the cooler, if you change/flush your trans fluid I would change that at the same time. yes both are serviceable/ can be changed. done plenty of research on it and know someone who has personally changed them
Now for the one that is inside the trans, this is all the info for the one under the trans including pan, filter, plugs etc
https://mitsubishiparts.net/parts/20...iagram=6255205
this is for a 13 SE, just go to the site go to your year model trim, and click "ENGINE" and you should see the image on the left
No I haven't done any of those yet. I believe the service interval for that is at 48K so it would be on my next service.
WRONG.....trans fluid change should be done btw 20-30k, not 48k. i would try that first lol. please do not believe your manual or what a service tech tells you if they said 48
https://www.mitsubishicars.com/owner...nance-schedule
I think that's why its so confusing. They never told me it needed to be replaced when I took it in.
