Transmission failure..
#31
yeah I seen it in the manual I have now for the 15 lol , for all the 11-14 models it never states anything about the auto trans fluid, I guess mitsu FINALLY got smart in 15, I have the manual for every year lol, they probably just started it in the 14 than. but it states to change every 30k miles which for you in Canada it says 48km but yeah every 30k. I would get on changing that ASAP than. but I was still right lol :-)
#32
According to the service manual in the link it says 48K (download full schedule)
https://www.mitsubishicars.com/owner...nance-schedule
I think that's why its so confusing. They never told me it needed to be replaced when I took it in.
If you use the paddle shifters regularly I would suggest that you should go by the severe plan (for the transaxle oil change) if you want long worry free operation.
#33
I'll be phoning them soon to schedule a service and to explain the issues that I've been having.
I also just pulled my maintenance book from the vehicle and under the Severe Plan it states to change this at 48k km as well.
Anyway, they didn't say anything about it last time so I'll just play dumb if they ask.
Thanks for all the help guys!
#35
Well update time...
I did the tranny flush, cost over $200 with tax, and the RVR runs much better so far.
I've done about half a tank of driving and I'm not experiencing any of the previous symptoms so far which is good.
It also seems that my mileage has increased but I will need to top her up first to see how many extra km I get.
Thanks again for the help.
#37
Would it be an issue of Transmission if and when from a stop: accelerating (not WOT) but just regular daily driving that it goes through 1st gear quick and then Rpms go low to 2k and turning on ECO mode at the same time? kind of like a hesitation and I don't get a good pull unless I Am TRYING to reach for 3-5k rpms?
#38
like it feels like your powerband is dropping off completely after that first shift?
let me know, because we just picked up our 2012 OS SE AWD CVT and thats what i'm feeling
#39
are you talking about - when you're accelerating from a stop, it goes through "first gear" and then the rpms drop a LOT - and you actually have to press your foot onto the gas even more to continue getting the same power?
#40
This figure also explains why:
1. the rpm rises if you switch from D to manual mode nearly at any speeds,
2. some higher pseudo gears are not accessible below certain speeds, and
3. the gears are really virtual (only gear 3 and 4 have linear characteristics the others are tweaked at certain points.
NB: This figure was generated from the repair manual of the 2011 model year (4B11). The CVT has been programmed couple of times (nearly with every model year) since.
#42
alphawav
Mitsubishi TC-SST Discussion
511
Oct 25, 2022 11:34 AM
evo 1768
27
Jun 1, 2009 05:11 AM
DaveJustDave
Jul 5, 2008 06:57 AM
DaveJustDave
14
Oct 11, 2007 07:08 PM
