Spark plug advice needed.
So I currently have iridium spark plugs put in by English racing about 50 k miles ago. Recently I started having my knock sensors flash on when I get around 6-8 k rpm especially when the car is under load at max boost 23.5 which cuts my fuel n makes the car go limp. I can recreate the knocks by hitting full boost. It would happen about 60% of the time.
What's the prefered spark plug and gap? I'm on stock turbo at 350 whp.
I'm guessing you didn't have any issues up until now? I'd start by checking the plugs if you haven't. Thought I had a boost leak or fuel problem myself with same thing as you described, turns out it was just time for some new plugs. Ironically I had about 50k on my plugs as well. Off the top of my head I don't remember exactly which ones I replaced them with but will dig around for you later if it'll help.
Yes new plugs. Mine did the same thing last year.
Yeah I ended up purchasing a set of BPR7EIX and a set of BPR8EIX. They are both iridium.
Got each set for about 35 dollars on eBay. I'm gonna play around with both sets to see which one my car likes better. Also trying to figure out how much I should gap it.
FYI...Normally you don't gap iridium plugs because they come pre-gapped, although you can check the gap if you are very careful. The iridium electrode is very brittle and not hard to break off.
You run the risk of doing more harm than good by trying to gap them...if you are really concerned with the gap, CAREFULLY check the gaps and go from there.
Seeing how you are lightly modded, you could probably get away with copper NGK plugs a step colder or two than stock. I run NGK BPR7ES gapped at .26 and I'm good to go!
guapoholic
24
Feb 24, 2017 07:47 PM
babaz7
Feb 3, 2016 08:48 PM
kikiboi
12
Jul 6, 2007 12:49 PM
krillin
Feb 6, 2007 10:01 AM
