paint fade.... - evolutionm.net
Paint and Detailing Discuss topics related to car paint (interior or exterior) and detailing (techniques, products, etc.).
paint fade....
Thread Tools Search this Thread
Old Apr 3, 2012, 09:33 PM   #1
Drives: 03 RR EVO 8
paint fade....
i bought my 03 in january and the previous owner did not take care of the of the exterior. well it had bad paint fade. i used meguiars rubbing compound, polish and wax and it took off all the fade. now my problem is it seems like if i dont wax this thing every week or so it wants to come back. im not really worried to much bout it since i have some rust spots on the left rear quarter and other areas. should i change wax? or am i just doomed until i get the car repainted in a couple years?
Offline
Old Apr 4, 2012, 11:57 AM   #2
CJ2X's Avatar
Drives: WW IX
Once the paint is ruined, you can't really reverse it. Try a buffer and some liquid wax and see how it goes..
Offline
Old Apr 4, 2012, 06:36 PM   #3
Drives: 03 RR EVO 8
ill give that a shot. ima switch wax to and see if that makes a difference. i keep calling it paint fade but it wasnt that it was like something with the clear. the clear is still there just wants to get cloudy again. here are some pics of what i mean it looked like. this was after only the the rubbing compound before i used the polish.
this is what it looked like before.
this is after.
Offline
Old Apr 24, 2012, 05:09 PM   #4
maiku's Avatar
Drives: 07 Si
What wax are you using? I would definitely try some different waxes out to see if they will hold out longer. Is the car always garaged?
Offline
Old Apr 24, 2012, 05:11 PM   #5
maiku's Avatar
Drives: 07 Si
Also, I recommend using a good sealant first, before waxing. I use JetSeal 109 by Chemical Guys. http://www.google.com/products/catal...ed=0CD8Q8wIwAg
This needs to be applied BEFORE wax. If you have wax on there now, remove it first before sealing.
Offline
Old Apr 25, 2012, 09:25 PM   #6
Drives: 03 RR EVO 8
Meguiars Gold Class Carnauba is the wax i use. im gonna try to seal it then wax it with something else. and no its never garage kept.
Offline
Old Apr 29, 2012, 07:42 PM   #7
FJF
FJF's Avatar
Drives: IX SE
Wax isn't going to solve the issue. As a first step, use a chemical cleaner to remove the oxidation. Then, polish. Wax is last in line. Refer to the applicable tutorials for specifics:
http://www.autopia.org/forum/car-det...ces-newbs.html
Offline
Old Apr 29, 2012, 08:32 PM   #8
FedEvo8's Avatar
Drives: 2003 RR EVO, 2005 CBR 1000rr, 2006 Passat 2.0T, 1990 International P-1000
Just FYI, 03 Rally Reds did not come with a clear coat. Had the same problem.
Offline
Old Apr 30, 2012, 04:57 AM   #9
FJF
FJF's Avatar
Drives: IX SE
...deleted...
Offline
Old Apr 30, 2012, 07:21 PM   #10
Drives: 03 RR EVO 8
i used the Meguiars compound to clean off the oxidation then the Meguiars polish then the wax. if thats the case it didnt come with a CC ill talk to my buddys at the body shop i know and see what they can do bout getting it cleared.
Offline
Old Jun 7, 2012, 01:28 AM   #11
The clear looks like it's oxidizing. If this happened to me, my last ditch effort would to gently wet sand the car with 2000 grit sandpaper to get rid of the top layer (just shaving a mm-ith) off. Then, i'll compound it, glaze it, polish it and then wax it. If there's enough clear, this might work and it'll last for years.
If the clear isn't salvageable.. then you'll still end up respraying so it wouldnt hurt to learn/try something new.
Before anyone flames me on the sanding part.. I've been working in the auto body/refinish industry for 4+ years.. )
Offline
Old Jun 7, 2012, 05:03 PM   #12
FJF
FJF's Avatar
Drives: IX SE
I agree; the paint seems to be oxidizing. As a first step, I'd suggest using a strong chemical cleaner: Klasse All in One, Duragloss 501, Werkstat Prime Strong. Wet sanding is a last resort.
Offline
Old Jun 7, 2012, 09:08 PM   #13
Drives: 03 RR EVO 8
i might try that. i hit it with a rubbing compound again and it looks beautiful. its looking like every 4 or 5 months i will have to do that.
Offline
Old Jun 7, 2012, 09:43 PM   #14
Drives: 2012 Evolution X
I agree with Klasse AIN, like FJF suggested. I used it on an oxidized car before after I polished the paint. It never came back.
Offline
Old Jun 7, 2012, 09:48 PM   #15
Quote:
I'd suggest having someone experienced measure your paint and do some corrective work. It shouldn't be that often that you need to compound it as long as the paint is taken care of.
Offline
Thread Thread Starter Forum Replies Last Post
Door handle and mirror fade bjmauck Paint and Detailing 4 Jun 30, 2013 04:52 PM
Paint fading Tapsta Lancer General 6 Feb 7, 2012 02:32 PM
Will stickers / vinyl cause paint fade marking? migs647 Evo X Show & Shine 22 Jul 31, 2011 08:32 AM
I need a Detailer, help Lancerguy'03 North Texas Evo Club (NTEC) 12 Mar 25, 2011 10:23 AM
Roof trunk and hood paint fading? EVOLUTIONIZE Evo General 16 Sep 21, 2010 04:50 PM
Tags
07, ca, evolutionm, fade, jobs, oceanside, paint, painting, powered, repaint, si, vbulletin
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
