Evo 4, my first project car
Engine shop is done. They honed cylinders, machined the block surface, machined crank journals under size, balanced the rotating assembly, machined flywheel, checked the piston and bearing clearances and machined the off set weights off the oil pump balance shaft to create my version of many performance shops "race shaft"
Not much to update. Havent done a lot lately. I installed the oil squirters and now have ARP main studs so I will get round to building the bottom end in the next few weeks hopefully.
Got crank bolted in today, got .05mm of oil clearance on the mains and .1mm of crank end play. Bolted down to 80nm. Next job is to assemble pistons and rods and then bolt them to the crank.
Today i checked my ring end gaps and here are the results. I would welcome any feed back on if i have them to tight, loose or about right form you experts.
Wiseco specs:
Top Ring: 0.4mm/ .015"
2nd Ring: 0.5mm/ .019"
My results
Cylinder 1
Top Ring: .35mm/ .013"
Second Ring: .65mm/ .025"
Cylinder 2
Top Ring: .4mm/ .015"
Second Ring: .55mm/ .021"
Cylinder 3
Second Ring: .5mm/ .019"
Cylinder 4
Again any thoughts on these results would be great.
Wiseco specs:
My results
Cylinder 1
Cylinder 2
Cylinder 3
Cylinder 4
Over the last few days I have been assembling the pistons, rods, rings and big end bearings and installing them while checking the oil clearance and the thrust clearance on the rod ends.
I got really lucky today sort of. When I torqued up the big end caps to 60nm it just felt a bit loose and i thought nothing of it really but I just had this slight nagging feeling from time to time so i checked the calibration of the wrench with a digital unit that a friend has and we found out that the adjuster inside the torque wrench had worked its self loose and was reading about 35nm low. I got it sorted all out and then retorqued the bigends and mains.
