EVOLUTION VIII - 2.3 Stroker Project
Old Jun 14, 2015, 09:35 PM
  #31
Kevin Troy's Avatar
Thanks guys, I really appreciate it
some good news, two very nice peaces are coming as update
Kevin Troy is offline
Old Jun 15, 2015, 10:26 AM
  #32
frankmabo's Avatar
Remember you need to balance the crankshaft with the pulley and the clutch kit installed(except the disc) in order to get the true 0.0x rotational balance.
Even if you are using a self adjusting silicone or gel based pulley you should balance it!
don´t leave that out in this beautiful build!
frankmabo is offline
Old Jun 15, 2015, 11:12 AM
  #33
o-townFLA's Avatar
Another belt you need to replace if you haven't yet, is your balance belt... I've had mine let go during a track session right at full WOT and destroyed my intake valves, Cosworth intake cam, and pistons
o-townFLA is offline
Old Jun 15, 2015, 12:55 PM
  #34
Mr. N's Avatar
Looking good so far . Can't wait for the next updates.
Mr. N is offline
Old Jun 15, 2015, 01:33 PM
  #35
EvoM Community Team
fostytou's Avatar
Great looking headwork and attention to detail overall!
No big worries if the accessory belt breaks other than a tow. If you don't notice it you could overheat the car, but that would be pretty difficult to not notice with no power steering / ac / power loss from the alternator / etc.
fostytou is offline
Old Jun 15, 2015, 04:10 PM
  #36
Erik@MIL.SPEC's Avatar
Once you've vented the block, where does that AN line run to? Another catch can? Atmosphere? I only see you venting from the head to the catch can...
Erik@MIL.SPEC is offline
Old Jun 16, 2015, 01:07 AM
  #37
kikiturbo's Avatar
i have had the acc belt break and take out the cambelt and everything above the head gasket..
kikiturbo is offline
Old Jun 16, 2015, 05:39 AM
  #38
lang13's Avatar
Thanks for the great photos, I really enjoyed looking at this build
lang13 is offline
Old Jun 16, 2015, 12:12 PM
  #39
Kevin Troy's Avatar
Thank you for bringing that to my attention, I will consider it and check with my mechanic
I have replaced it 4 years ago together with cosworth Kevlar timing belt.
My initial plan was to vent the block via hose and on top a small filter and see how it will behave.
Another possibility will be to connect it to catch can and then to the turbo.
Will test when done the swap
Thanks, new package is on the way
Old Jun 17, 2015, 05:43 AM
  #40
SHIFTT IX MR's Avatar
The EVO looks good, for a red car :P What brand Lift are you using? I am looking at one just like it now for my house. Would appreciate a response.
SHIFTT IX MR is offline
Old Jun 17, 2015, 08:02 AM
  #41
Kevin Troy's Avatar
Hi,
I'm not quite sure what you mean by "brand lift"? Do you mean the Engine holder (stand)?
If yes, it's a regular engine stand (500LBS).
Old Jun 18, 2015, 06:39 AM
  #42
abnt89's Avatar
Originally Posted by Kevin Troy
Hi,
I think he was talking about this lift.
abnt89 is offline
Old Jun 18, 2015, 06:44 AM
  #43
SR Concepts's Avatar
I believe it's this company as I ordered one for my shop at home
http://www.ecvv.com/product/3782885.html
SR Concepts is offline
Old Jun 18, 2015, 09:15 AM
  #44
Kevin Troy's Avatar
aaah, ok, if that's the case then I don't know the brand, must check with my mechanic
Old Jun 23, 2015, 03:03 PM
  #45
kiggly's Avatar
Love all the photos in this build! And thanks for including Kiggly in the build too
Keep up the good work!
kiggly is offline
Quick Reply: EVOLUTION VIII - 2.3 Stroker Project
