FS[SouthEast]: 4 Piston CNC head, ARP 625+ studs, Radium catch can
Selling a few things I was going to use for a spare motor/build but I decided to take a brake from the Evo for a bit and I'm not going to build a 2nd motor.
Brand new 4 Piston Racing CNC head with ALL the options. This head was also built with a Brand new OEM core!
SOLD!
This is a set of ARP 625+ head studs for the Evo X. These studs where used once and where in use for less then 2000 miles.
I measured all the studs and they're all within 0.002", I called ARP and they said that's the original spec and that these studs can be reused up to 10 times.
I ended up replacing them because I thought I had blow a head gasket so I bought a new set just incase but it turned out to be something completely unrelated.
$300 shipped and PayPal'ed to the lower 48.
Next is a Radium Engineering catch can. This is the can with the bracket to mount by the passenger side headlight.
I'm also including a universal mounting bracket, a Petcock drain valve, the fittings you see and 2 different filters so you can change the look if you wish.
What you see is what you get,
SOLD!
SOLD!
SOLD!
black E
Aug 29, 2016 10:25 PM
dsm25psi
14
Nov 20, 2014 07:21 PM
extremepsi
Evo 'For Sale' Engine Internals and Drivetrain
Feb 19, 2013 12:01 AM
DIDYSIS
Oct 19, 2008 11:19 AM
