Power Acoustik CK-12D Kevlar Subwoofer, box, amp & capacitor
I have for sale here a Power Acoustik subwoofer model CK-12D that features a yellow KEVLAR cone with a massive 224OZ magnet. Also a custom made subwoofer box made from 3/4" MDF that is specifically made for this sub because this sub is actually more like a 13" and requires a larger cutout than a standard 12" woofer. The box is sealed and is in excellent condition. The carpet on the box is black indoor/outdoor carpet and has help well, the carpet job on the box is a 7/10, although nobody will notice the box after they see how cool the sub is. The amplifier is a 1000watt 4 channel Legacy LA-1030 Series 4 that is bridged between each of the speakers dual voice coils to provide 2 ohm power to the sub. The sub could take a bigger amp, although this one work great and has a lot of adjustability and the gain adjustments are only turned up half way so there is plenty of power to spare. The capacitor is a 1 farad Sound Quest model 1cap(without LED readout) that works great and will stop your lights from dimming. This is a great combo for someone looking for tight base to take up less space. Sorry some of the pictures are low quality, these are from my Sprint-PCS picture phone and it is the best it can do. You will not be disappointed with this setup. Individual specs are below:
Power Acoustik CK-12D Farenheit Subwoofer
12" Subwoofer 1000 Watts RMS SEALED ENCLOSURE
Kevlar Fiber, Ceramic Coated Cone
Oversize Butyl Rubber Surround
Dual Hybrid 4 Layer 4 Ohm Voice Coil
3 High Temperature A.S.V. Voice Coil
Die-Cast Basket
Ultra Stiff Flat Spider
Low Q Driver (.75~1 CUFT. Sealed Box)
Sealed, Ported, Free Air & Band Pass Configurations
Vented & Extended Pole Piece
Nickel Plated Bumped Back & Front Plate
Gold Plated Binding Posts
224 oz. Magnet Structure
Maximum Input 2000 Watts
R.M.S. Input 1000 Watts
Imp. 2 Ohm, 4 Ohm, 8 Ohm
Freq. Resp. 18Hz-1kHz
SPL 92 dB
LEGACY LA-1030 4 CHANNEL 1000 WATT BRIDGEABLE MOSFET AMPLIFIER
Four-Channel Bridgeable Amplifier
Tri-Way Mode Output
4 X 250 Watts Output
2 x 500 Watts Bridged Mono
MOSFET Pulse Width Modulated Power Supply
Fully Variable Hi/Lo Pass Crossover Network
Variable Bass/Treble Boost(0~12dB)
2 Ohm Stereo Stable
Gold Plated RCA Line Inputs/Outputs
Soft Turn On/Off Circuit
Heavy Duty Aluminum Heatsink
Discreet Wire Connections
Variable Gain Controls
Remote Turn On/Off
Speaker Terminal Barrier Strip
Power On/Protection/Clipping LED Indicator
Input Sensitivity:100Mv ~ lv Adjustable
Input Impedance:10 k Ohms
Signal to Noise Ratio:>95dB
THD:>0.04 @ RMS Power
Frequency Response:10Hz- 30kHz
Overload/Short Circuit Protection
Thermal Shutdown
Dimensions:10.5''W x 2.3''H x 17''L
$100 + actual shipping. It doesn't get any better than this!
Die-Cast Basket
SPL 92 dB
Tri-Way Mode Output
2 Ohm Stereo Stable
Remote Turn On/Off
Thermal Shutdown
