[FS] Manley Turbo Tuff I-beam rods 156mm for long rod setup 2.0lr 2.4 2.2
Old Feb 25, 2017, 08:58 PM
gSx
gSx's Avatar
Excellent condition rods, no spun bearing or anything. I included the bearings that i was using so you can have confidence. 156mm for building a long rod motor or whatever you're doing. I ran them in my 4G69 engine build but i scratched the bore and its already 87mm so i wont be boreing that any more. The compression was 90psi on the scratched cylinder after i tried rolling with it. I'm going back to a standard 2.0. $600
Also have Manley 619220c-4 pistons that look great and a Manley billet 94mm crank
gSx is offline
Old Mar 1, 2017, 08:20 PM
gSx
gSx's Avatar
bump
gSx is offline
Old Mar 28, 2017, 07:53 PM
gSx
gSx's Avatar
bump
gSx is offline
Old Mar 29, 2017, 08:48 PM
Tonyc_83's Avatar
I have a 2.4 that I need to bore out to 87mm
What you have will work for me or no?
Current status is 2.4LR 86.5 mm (needs oversized pistons)
My 100mm crank is dead ( cracked #4 journal)
So I need pistons and a crankshaft
Tonyc_83 is offline
Old Mar 29, 2017, 09:34 PM
gSx
gSx's Avatar
It won't work because of the block deck height. If you buy a 2.4L 4g69 block out of an outlander or lancer ralliart then it will be ideal. The 69 deck height is the same as the 4g63 but has 87mm bore. Thats what i was running and it was a street monster! I have everything you need to build the 2.2L de-stroker and a damn good deal too
gSx is offline
Howulikemyevo
12
Feb 28, 2016 08:41 PM
Evosick2332
Jul 1, 2014 09:02 AM
usacchamp
23
Jun 10, 2014 04:26 AM
Darkn3s
Feb 19, 2014 05:01 PM
Street gear
Jun 19, 2011 10:11 PM
Quick Reply: [FS] Manley Turbo Tuff I-beam rods 156mm for long rod setup 2.0lr 2.4 2.2
