JL Audio 12W6V2 with box, MTX Thunder 202, Alphasonik 5 channel amp with capacitor
Here are pics of all items
MTX amp-50.00
JL Audio sub with box-250.00
Alphasonik 5 channel amp w/ capacitor-250.00
Specs for each
MTX Amp
Amplifier Type: 2-channel
RMS Power @ 4 Ohms: 50W x 2 @ 14.4V
THD at 4-Ohm RMS Power: <1%
Bridged RMS Power @ 4 Ohms: 200W x 1 @ 14.4V
Speaker Level Inputs: Yes
Preamp Outputs: Yes
Built-In Crossovers: HP/LP
Bass Boost: n/a
Frequency Response: 20-20,000 Hz
Signal to Noise Ratio: >100 dB
Fuse Rating: 20 amps
JL Audio 12W6V2 sub
http://jlaudio.com/subwoofers/12w6v2.html
Nominal Diameter: 12 inches (300 mm)
Continuous Power Handling: 400 Watts
Voice Coil: 2.75" diameter, 4-layer, Kapton former
Available Configurations: Dual 4 ohm only
Xmax (one-way, linear): 0.65" (16.5 mm)
Sealed Enclosure Range: 0.90-1.50 cu.ft. (25.0-42.0 liters)
Ported Enclosure Range: 1.25-1.75 cu.ft. (35.4-49.5 liters)
VRC™ Technology: YES
W-Cone™ Technology: YES
Elevated Frame Technology: YES
Floating Cone Attach Technology: YES
NeckVent™ Technology: YES
Alphasonik Amp
5-Channel Class A/B Bipolar Power Amplifier
RMS Power Rating: 75 watts x 4 chan. + 200 watts x 1 chan. at 4 Ohms Stereo
RMS Power Rating: 120 watts x 4 chan. + 320 watts x 1 chan. at 2 Ohms Stereo
RMS Power Rating: 150 watts x 2 chan. at 4 Ohms Mono
RMS Power Rating: 320 watts x 1 chan. at 4 Ohms
Bridgeable
Tiffany-style input and ouput RCA jacks
RCA and Speaker Inputs(Low/High Level)
MOSFET high speed switching power supply
THD: 0.06%
S/N Ratio: >100dB
Frequency Response: 5Hz-50kHz
Variable High Pass/Low Pass Filter: 50Hz-250Hz, 18dB/oct
Variable Subsonic Filter: Off-20Hz, 18dB oct
Variable Bass Boost at 45Hz: 0-18dB
Variable Phase Shift: 0-180 degrees
Input Impedance: 10K ohms
4-way protection circuitry: thermal, short circuit, overload and DC offset
Direct input terminal/PCB contact
Dimensions: 18 15/16L x 9 1/4W x 2H
1-year Sonic Electronix warranty
Amplifier Specifications:
Number of Channels 5
RMS Power (4 ohms) 75 watts x 4 chan. + 200 watts x 1 chan.
RMS Power (2 ohms) 120 watts x 4 chan. + 320 watts x 1 chan.
RMS Power (1 ohm) Not Stable
Bridged RMS Power 150 watts x 2 chan. + 320 watts x 1 chan.
Peak Power Output 1280 watts approx.
Min. Impedance Unbridged 2 ohms
Min. Impedance Bridged 4 ohms
THD @ Rated RMS Power 0.06%
Speaker Level Inputs Yes
Amp Preamp Outputs Yes - 1 Pair
Built-in Crossover LP ( 50 - 250 Hz), HP ( 50 - 250 Hz), Subsonic (Off - 20 Hz)
Bass Boost 0 - 18 dB
Signal-to-Noise Ratio >100dB
Fan Cooled N/A
Fuse Rating 40A x 2
Warranty 1-year SE
MTX amp-50.00
Specs for each
MTX Amp
Preamp Outputs: Yes
Bass Boost: n/a
JL Audio 12W6V2 sub
Alphasonik Amp
Bridgeable
THD: 0.06%
S/N Ratio: >100dB
Fan Cooled N/A
Fuse Rating 40A x 2
Warranty 1-year SE
Englando
54
Jun 1, 2014 09:12 PM
ToddRhodes
11
Jun 12, 2013 12:12 PM
dbsears
Nov 11, 2008 01:51 PM
