Kenwood KDC-X789-MP3 player
This is a really nice radio for sale.
Here are the specs
Display Modes: The Kenwood KDC-X789 features a large, bright, 64-color fluorescent display with 5 selectable display modes:
Graphic Display (Display Type A): You can choose between 3 "movies" or a slideshow of 6 still images. Text information is displayed briefly for tuner and CD functions before graphic reappears.
Graphic + Text Display (Display Type B): The same Graphic Display is shown, plus one line of text is displayed. Selectable text information is available for each source.
3-line, 2-column Text Display (Display Type C): Three lines of text information are displayed, each with a text label icon and the text display. You can choose what information to display for each line (clock, frequency, playback time, CD text, ID3 tags, etc.), plus choose a text display color between white, yellow, or blue.
Text + Source Icon Display (Display Type D): Two lines of text information are displayed (selectable information and colors). On the right end of the display is an icon to indicate the currently selected source. The bottom line features function labels for the multi-function keys located directly below.
G-Analyzer Display (Display Type E): Measurements of G-forces (gravity) on the vehicle are displayed. You can select between "G-Graphic", G-Meter (Graphic), G-Meter (Text), or G-Counter display.
Picture Downloading: You can download one movie and one wallpaper image from a special Kenwood website for use in the above Graphic Displays. New images can be recorded onto a CD-R or CD-RW disc, and loaded into the receiver.
G-Analyzer: This unit is equipped with a sensor that measures the forces of gravity on the vehicle. This sensor enables the receiver to calculate G-forces during acceleration, braking, and cornering. The G-Analyzer also has a stop watch that can be automatically started when forward or reverse G-forces are detected. Setup and calibration for acceleration and braking must be performed before using the G-Analyzer.
AAC/MP3/WMA Playback: The receiver can play AAC, MP3 and WMA files recorded on CD-ROM, CD-R, and CD-RW discs in ISO9660 Level 1/Level 2, Joliet, and Romeo formats. Each disc should have a maximum of 8 directory levels, 100 folders, and 4096 files per folder. During MP3/WMA playback, the unit displays any recorded ID3 Tag information. AAC ID3 tags cannot be displayed.
Kenwood Advanced CODEC Drive: The KDC-X789 features Advanced CODEC Drive (ACDrive) to help you organize your digital music files and burn CDs with advanced features. With the PhatNoise Media Manager (on the supplied CD-ROM software), you can browse compressed audio files by playlists, artists, albums or genres. The receiver's built-in Voice Index will "announce" artist, album, and genre names when an ACDrive disc is played. The software will also help you rip music from CDs and encode them as AAC files. To help you keep up-to-date, the Media Manager software allows you to download new CODECs and features and download them to a CD for upgrading the receiver. (See Minimum Computer Requirements below for installing the software on your computer).
24-Bit Burr-Brown D-A Converter: The KDC-X789 features an audiophile-quality 24-bit Burr-Brown digital-to-analog converter for superb CD sound. The Burr-Brown D-A converter maximizes the musical resolution of CDs, CD-R/Ws, and AAC/MP3/WMA-encoded discs.
System Q-EX Sound Control: Six EQ curves are preset into memory, allowing you to recall the best preset EQ curve for different types of music: Rock, Pops, Easy, Top 40, Jazz, and Natural. In addition, you may store your own settings under the "User Memory" EQ curve. Each preset has its own bass center frequency, bass level, bass Q factor, bass extension, middle center frequency, middle level, middle Q factor, treble center frequency, and treble level settings. You may adjust the bass center frequency (40, 50, 60, 70, 80, 100, 120 or 150Hz), bass level (-8 to +8), bass Q factor (1.00, 1.25, 1.50 or 2.00), bass extension (On or Off), middle center frequency (0.5, 1.0, 1.5 or 2.0kHz), middle level (-8 to +8), middle Q factor (1.0 or 2.0), treble center frequency (10.0, 12.5, 15.0 or 17.5kHz), and treble level (-8 to +8). The System Q EX can be turned off in the menu, still allowing you to adjust the bass, middle and treble levels only.
Subwoofer Preamp Output: The KDC-X789 is equipped with a pair of subwoofer preamp outputs. The subwoofer outputs can easily be turned on/off. When the subwoofer output is turned on, you can adjust the volume (-15 to +15 in increments of 2), set the low pass filter cutoff (50Hz, 60Hz, 80Hz, 100Hz, 120Hz, or Through), and the phase (normal, reverse).
System E's+: In addition to System Q Sound Control, the KDC-X789 features the System E's+ crossover system for the speaker and preamp outputs. You can make the following adjustments:
Front High Pass Filter: 40Hz, 60Hz, 80Hz, 100Hz, 120Hz, 150Hz, 180 Hz, 220Hz, or Through (no filter)
Rear High Pass Filter: 40Hz, 60Hz, 80Hz, 100Hz, 120Hz, 150Hz, 180 Hz, 220Hz or Through (no filter)
Low Pass Filter: 50Hz, 60Hz, 80Hz, 100Hz, 120Hz or Through (no filter)
Source Tone Memory: This feature allows you to store System Q bass, middle and treble tone settings for each source (CD, FM, AM, Satellite, and CD changer).
Volume Offset: The level of each source may be independently adjusted to prevent radical leaps in output volume when switching from one source to another. The available settings range from -8 to 0.
Built-in Amp Switch: If the audio signals are output to external amplifiers, you can turn off the internal amplifier to improve audio quality.
Dual Zone System: The KDC-X789's Dual Zone System allows you to output one source to the front channels and another source to the rear channels. The main source can be the internal disc player, tuner, or a source connected via the 13-pin CD changer input. The sub source is a device connected to the rear RCA auxiliary input. You can assign the sub source to either the front or rear channels. When the Dual Zone System is activated, the volume of the front channels is controlled by the volume knob, while the volume of the rear channels is controlled in the Audio Control menu.
CR-2 Advanced Tuner: This unit uses Kenwood's CR-2 Advanced tuner for clear radio reception. You can choose one of three tuning modes: Auto 1 (seek tuning), Auto 2 (cycles through and tunes the selected band's preset stations only with each button press), or Manual.
HD Radio Ready: With an optional Kenwood HD Radio tuner (item # 113KTCHR10), you will be able to receive digital AM/FM broadcasts from local stations where available. This new technology will significantly improve audio quality and reception, as well as include information such as artist name and song titles or traffic news, viewable on the receiver's display.
Radio Data System (RDS): The unit's tuner features RDS (Radio Data System). RDS is a service used by some radio stations to transmit data outside of normal radio broadcast signals. When an RDS station is received, you can immediately find out what kind of data is being transmitted by looking at the program service name which appears in the display after the frequency. RDS features an emergency transmission function which interrupts regular programming to broadcast an emergency announcement (such as a tornado or severe storm). There is also a switchable Traffic Information function, which will automatically tune a traffic bulletin when it is broadcast, even when you're not listening to the radio.
Clean Reception System Circuit (CRSC): This circuit controls multi-path distortion by reducing stereo separation. As stereo separation is reduced, multi-path has less effect on the radio signal, improving reception in areas with tall buildings and mountains. The CRSC circuit can be turned on or off.
Disc/Station Naming: You can enter and store names of up to 8 characters for CDs and radio stations. Characters can include upper case letters, numbers, symbols, and special accent characters. The memory can store names for up to 30 stations and 10 discs in the internal CD player. The number of disc names you can store for an external CD changer depends upon the capability of the changer.
Disabled System Indicator: A red indicator will blink on the unit after the faceplate is removed, warning potential thieves. This feature can be turned On or Off.
Security Code: You can enter a 4-digit security code which must be used when the unit is removed from the vehicle, or the constant power source is disconnected from the unit. When constant power is restored to the unit, the security code must be entered before the unit becomes operational. The security code may be disabled if desired.
Bass Management System (B.M.S.): You can remotely adjust the bass boost of a compatible Kenwood amplifier with the Bass Management System (B.M.S.). When properly connected, you can set the bass boost to Flat, +6dB, +12dB, and if the amplifier is capable, +18dB. In addition, you can set the B.M.S. frequency offset to "Normal" or "Low". The "Low" setting drops the bass boost normal center frequency by 20%. Note: The pink/black lead on the receiver's wiring harness should be connected to the amp's B.M.S. terminal.
Remote Control: The KDC-X789 comes with the RC-527 wireless remote control with a full numeric keypad. The remote includes volume control for the rear channels when the unit is operating in the Dual Zone mode. It is powered by 2 "AA" batteries (supplied). The dimensions of the remote are: L=5.369", W=1.968", D=1.198".
Display Illumination/Clock Display: When the unit is in Standby mode, the face/button illumination is "keyed". In addition, while the unit is in Standby mode, you can turn the clock display on or off." When the Clock Display is turned on and the unit is in Standby mode, the Clock Display is also "keyed". Pressing and holding the source button turns the unit off completely.
Display Dimmer: When the dimmer control is set to "on", the display automatically dims when the vehicle lights are turned on. When set to "off", the display doesn't dim. Note: In order for the display dimmer feature to operate, the orange/white wire in the supplied wiring harness must be connected to the vehicle's headlight circuit.
Auxiliary Input: The KDC-X789 is equipped with a built-in auxiliary input. There is a set of stereo RCA jacks on a 12-inch pigtail on the back of the receiver for connecting an external audio source. The Auxiliary input can be activated/deactivated through the menu. When it's activated, you can select one of six names for the source: Aux, TV, Video, Game, Portable or DVD. When deactivated, Auxiliary does not appear as a source. With an optional adapter (item 113CAC1AX or 113KCAS210), you can also turn the unit's CD changer input into a second auxiliary input.
Changer Controls
Compatibility: This unit is directly compatible with Kenwood changers manufactured in 1998 or later. If the changer has an O-N switch, the switch will need to be set to the "N" position. If you have a Kenwood changer manufactured before 1998, you will need the KCA-S210A switching adapter. Changers manufactured before 1994 require the CA-DS100 converter cord (113CADS100) and the KCA-S210A switching adapter.
Changer Controls: In addition to basic disc navigation features, this unit has the following changer controls: direct disc access (using the remote), direct track access (using the remote), track intro scan, track repeat, disc repeat, disc random, and all disc random.
CD Text/MD Display: When connected to a CD Text capable CD changer or an MD changer, this unit can display disc and track titles for discs encoded with disc and track title information. The text information can be scrolled manually or automatically.
PhatNoise Media Manager Software: To use Media Manager software, the following software and hardware are required:
Software: Microsoft Windows 98SE, ME, 2000, or XP
Hardware:
Personal computer (main unit, display, and peripheral units) incorporating a 500MHz or better Pentium II processor (or the equivalent) on which the above OS can run normally
128MB RAM or more
Hard disc with 200MB free space
CD-R/CD-RW drive
Others: Internet connection environment
Note: Administrator authority is required when installing Media Manager in Windows 2000 or XP
175.00
Here are the specs
Changer Controls
Hardware:
128MB RAM or more
CD-R/CD-RW drive
175.00
nybluelancer
Feb 17, 2017 04:33 PM
08GtsLancer
15
Dec 12, 2011 10:03 AM
Spoonie
50
Jun 23, 2009 01:58 AM
t3t418t
May 17, 2005 09:14 AM
