Camp Lejeune/Jacksonville Evos (NEW)
Old Mar 4, 2010, 07:59 AM
EvoM Community Team
atombomb33's Avatar
Continued from here: https://www.evolutionm.net/forums/so...-evos-372.html
Have fun fellas
Old Mar 4, 2010, 09:15 AM
bigric09's Avatar
haha... Adam packed your **** up too lol
Old Mar 4, 2010, 10:00 AM
SRTRaceR04's Avatar
3rd!!!!
Old Mar 4, 2010, 11:14 AM
Jeovannie's Avatar
I'm in
Old Mar 4, 2010, 11:54 AM
Paintballer81's Avatar
hahaha we are the ****.
Old Mar 4, 2010, 03:58 PM
JReid's Avatar
i have never heard of a thread being too long, but hats off to us for just being that damn awesome.
Old Mar 4, 2010, 06:30 PM
sixers0307's Avatar
Hopefully i can get off work at noon...its a big maybe since we leave to ft. bragg on monday...our section is done with what we needed to do but we gotta wait on all the other sections. cross your fingers lol. I'll let you guys know if i get off at noon tomorrow. i'll txt you guys.
Old Mar 4, 2010, 09:15 PM
SRTRaceR04's Avatar
W3rd. If it ends up being just Matt and I I'm not too worried about it. Just figured I'd see if anyone would like to go. I'm always up for group road trips.
Old Mar 5, 2010, 08:17 AM
Psquared's Avatar
That's awesome! Maybe the server needs some methanol or something to help it out. :-)
Old Mar 5, 2010, 08:48 AM
SRTRaceR04's Avatar
^ Nice!
Hey Joe I'm gonna text you in a bit in case you don't see this. We're not going to Fayetteville anymore today. Had to reschedule with the tuner. No biggie (although slightly disappointed). Stuff happens though and my car can wait!!
We can probably get your gauges knocked out today/tonight though.
I want to try running the colder plugs in my car. It was running erratic up top before. Then for like a week it seemed to be running good. Then last night it was running kind of erratic up top again. I'm gonna try the colder plugs gapped at like 0.24 and see if that helps until I have the money for the COP.
Old Mar 5, 2010, 04:01 PM
alicea8541's Avatar
Hey Ben what's with this High Zinc Amsoil? Like I was looking at the bottles and mine is different than the 10w30 for my brother. Mine says high zinc. Is that because of the peculiar weight? I'm wondering if zinc is good or something.
Sounds like a good theory. I really don't know why that is. I will try to see what I can find.
First day this week I have been off before 7 and I am dragging some serious butt.
Old Mar 5, 2010, 04:14 PM
alicea8541's Avatar
This is on their website don't know if all of this was on the bottle.
PRODUCT DESCRIPTION
AMSOIL Synthetic 20W-50 Motor Oil is specially formulated to provide superior protection and performance in a wide variety of demanding applications. By incorporating high-quality synthetic base
stocks and a superior high-zinc additive package, AMSOIL Premium Protection Oil exceeds the needs of large and small gasoline or diesel engines in cars, motorcycles, trucks, motor homes, maintenance equipment, heavy equipment, street rods and marine applications. It is ideal for high-mileage vehicles, vehicles with flat-tappet cams and high-stress vehicles subject to hot temperatures, heavy hauling, trailer pulling or off-road use. AMSOIL Premium Protection Oil resists oxidation, neutralizes acids, inhibits corrosion, reduces wear and protects against deposits. It provides the extra anti-wear protection required by engines with flat-tappet cams and high-tension valve springs. AMSOIL Synthetic 20W-50 Premium Protection Motor Oil offers flexibility and performance beyond conventional oil for convenience and trouble-free operation.
AMSOIL, the leader in automotive synthetic lubrication, produced the world’s first API qualified synthetic motor oil in 1972. Trust the extensive experience of AMSOIL The First in Synthetics® to do the best job protecting your engine.
Provides Superior Wear Protection
AMSOIL Synthetic 20W-50 Premium Protection Motor Oil is a high viscosity oil engineered to protect against metal-to-metal contact. It resists viscosity shear and is formulated with a heavy treatment of zinc and other anti-wear additives for excellent protection of gears, bearings, cam lobes and other high-pressure components in engines and transmissions. AMSOIL Premium Protection Synthetic Motor Oil helps extend engine life.
Exceeds the Requirements of Wet Clutch Transmissions
AMSOIL Premium Protection Synthetic Motor Oil contains no friction modifiers, making it ideal for motorcycles, maintenance equipment and other wet clutch transmission applications. Formulated to prevent clutch glazing and slippage, it helps insure smooth clutch engagement and long term, dependable transmission operation. AMSOIL Synthetic 20W-50 Motor Oil reduces clutch wear for extended transmission life.
Resists Oxidation and High Temperature Breakdown
AMSOIL Premium Protection Synthetic Motor Oil is specifically formulated to overcome the thermal deficiencies
common to conventional petroleum oils. Volatilization (burn-off), oxidation and excessive deposit formation from high heat are greatly reduced. Viscosity thickening is controlled and engines run cleaner, promoting cooler operation and long engine life in air- or liquid-cooled engines. In addition, the higher viscosity nature of AMSOIL Synthetic 20W-50 Motor Oil may help reduce motor oil consumption in equipment that experiences higher-than-normal usage rates when lower-viscosity lubricants are installed.
Extends Drain Intervals in Gasoline and Diesel Engines
The superior AMSOIL synthetic base stock and additive technology exceeds the requirements of both gasoline and diesel engines. AMSOIL Premium Protection Motor Oil neutralizes acids, disperses soot and lasts longer in service than conventional oils.
APPLICATIONS
AMSOIL Synthetic 20W-50 Premium Protection Motor Oil is a multi-use, premium synthetic lubricant for applications that require or benefit from a higher viscosity oil. It is recommended for air and liquid cooled, large or small gasoline and diesel engines, transmissions and chaincase applications where 20W-50 oil is required with any of the following specifications:
•API SL, SJ, SH, SG
•API CI-4 Plus, CH-4, CF, CF-2
•ISO-L-EMA • Caterpillar ECF-1
•JASO MA (Motorcycle) • MAN 271/3275 • MTU Type 2
•Cummins 20071/20072/20076/20077 • VDS-2, VDS
•Mack EO-M+ • ACEA A3/B3, E3, E5 • MB 228.3, 229.1
•Detroit Diesel 93K214
MIXING AMSOIL
AMSOIL Synthetic 20W-50 Premium Protection Motor Oil is compatible with conventional and synthetic motor oils. Mixing AMSOIL motor oils with other oils, however, will shorten the oil life expectancy and reduce the performance benefits. AMSOIL does not support extended drain intervals where oils have been mixed. Aftermarket oil additives are not recommended for use with AMSOIL Synthetic Oils.
SERVICE LIFE
AMSOIL Synthetic 20W-50 Premium Protection Motor Oil is recommended for extended intervals in unmodified, mechanically-sound vehicles or equipment as follows:
Diesel Engine Service
•Normal Service - Up to 25,000 miles or one year, whichever comes first, or longer based on oil analysis.
•Severe Service - Up to 15,000 miles or one year, whichever comes first, or longer based on oil analysis.
Gasoline Engine Service
•Normal Service - Up to 15,000 miles or one year, whichever comes first, or longer based on oil analysis.
All this mumbo jumbo sounds like this stuff is getting it done.
Old Mar 5, 2010, 04:20 PM
alicea8541's Avatar
Ours was no where near the size of yours either. Oh well!
Old Mar 5, 2010, 04:34 PM
bigric09's Avatar
thats what she said
Old Mar 7, 2010, 12:30 AM
ch53avitech's Avatar
Some big things are happening to this guy when he get the money to do it.
Donations are welcome. Paypal me or something.
Quick Reply: Camp Lejeune/Jacksonville Evos (NEW)
