Wynn's fuel system cleaners distributors
Ok evom menbers, here it is to keep the thread on the right track, this will be our dedicated thread to any request for our 3 stage cleaner, 2 stage cleaner or even if you want to buy any single bottles of our cleaners.
Remember we are a sub distributor for Wynn's this allows us to provide the best prices at distributor pricing, these are the same prods you get at your local mitsu delaer, but at a higher price, here you get them at distrib pricing
For you motorcycles we reccomend the 2 stage, intake/TB sprayer, and the intank injector cleaner,
our 3 stage consist of : premium intank fuel system cleaner, intake/Throttle body 6oz can convinient spray, also our powerful V.I.C ( valve intake combustion chamber cleaner ) $65.00 shipped to your door.
- in tank easy pour, Fuel Injector Cleaner Part Number 65221A ( $13.50 ea )
- Air-Intake Cleaner Part Number 60807, cleans Throttle body, and intake manifold, ( $14.00 ea )
- V.I.C. Combustion Chamber Cleaner Part Number 61510 ( $ 35.00 ea )
V.I.C, is the biggest deal around here gives you the most cleaning advantages its a special blend that will clean all of your top end internals from intake/exhaust valves, intake manifold runners cleans like new, top of your pistons it takes all that old gunk that accumulates from the combustion process, oh and its safe on your seal we dont use Chlorinated solvents, actually by the way it actually lubricates them seals and parts instead.
we have tested it in our personal Evo9 and used a borescope to inspect the before and after results and we were amazed this product does what it claims, let us know we can email our test review if you want to see it.
[FONT="Times New Roman"][SIZE="3"] For our 2 stage package we have put together 2 of our best formulas power charge and intake/TB cleaner these 2 together will give you better MPG on your vehicle, smoothly clean your fuel system, injectors, intake exhaust valves, combustion chamber, top of your pistinons, in this package you wont use the VIC(valve intake, cumbostion chamber cleaner) however you will get power charge and it has a light blend of solvents and detergents its a power loaded cleaner its a whao after you run a full tank of it, and in complement with the intake/TB cleaner, [B]remember you are getting distributor pricing here on evom low low prices $ 45.00 shipped[/B
check out our thread for testimonials and some great results testing of our products, https://www.evolutionm.net/forums/sh...ighlight=wynns
also check out any technical you may have http://wynnsusa.com/fuel.aspx
