Evo X Product Updates and Additions at STM
Old Aug 31, 2016, 08:24 AM
4g63girl's Avatar
STM Tuned
43 Turner Drive
Spencerport, NY 14559
(585) 226-8226
www.stmtuned.com
STM has a huge stock of OEM Mitsubishi parts and it grows daily. Our Evo 8/9 OEM Section is massive and we are currently working on redesigning it so it's even easier to use. We would like to have the Evo X Section just as big soon!
Recently I had a hard time tracking down information on OEM Cam Bearings... of course our tech knew all about them and pointed me in the right direction, but I thought it could be useful for the forums to also have for the next guy searching.
I'll continue to update this thread with added items and if you're looking for something specific, just give us a call and if Mitsu still makes it, we can get it!
First off... these guys!
Genuine OEM Mitsubishi Evo X Camshaft Bearings
Part Numbers:
1016A030 (Mark #1)
1016A031 (Mark #2)
1016A032 (Mark #3)
When you remove your old bearing, there will be a number on it. Replace it with the corresponding bearing mark.
Old Aug 31, 2016, 08:28 AM
4g63girl's Avatar
Part Number: 7415A605
Genuine OEM Mitsubishi "Final Edition" 2015 Evo X Badge
Old Aug 31, 2016, 08:29 AM
4g63girl's Avatar
Part Number: MN107671XF
Genuine OEM Mitsubishi Evo X 2015 Final Edition 5-Speed Shift Knob with Red Stitching
Old Sep 1, 2016, 09:50 AM
4g63girl's Avatar
Part Number: 3200A145
Genuine OEM Mitsubishi Evo X Passenger Side Front Axle Seal (Transfer Case Output)
Old Sep 1, 2016, 10:58 AM
4g63girl's Avatar
Part Number: 3200A105
Genuine OEM Mitsubishi Evo X Rear Transfer Case Output Seal
Old Sep 1, 2016, 12:06 PM
4g63girl's Avatar
Part Number: MN132370
Genuine OEM Mitsubishi Evo X Transmission Output (LH) Front Axle Seal
For the USDM driver (LH) side front axle.
Old Sep 1, 2016, 01:01 PM
4g63girl's Avatar
Part Number: 1865A066
Genuine OEM Mitsubishi Evo X Camshaft Position Sensor
Old Nov 3, 2016, 11:48 AM
4g63girl's Avatar
Just finished up the OEM Evo X Rear Axle Differential Section.
All OEM Parts and fitments are listed and available!
Easy to find and easy to buy.
(34025) MR580044 Rear Diff Support
Fits: All 2008-2015 Evolution X
(34033A) 3501A121 1 Rear Differential (Full Assembly)
(34035) MV026287 2 Bleeder Screw Cap
(34046) MR222005 1 Rear Diff Carrier Cover
(34072) 3415A015 1 Rear Diff Companion Flange
(34106) MB393929 1 Rear Diff Drive Pinion Oil Seal
(34109L) 3515A049 1 Rear Diff Axle Seal (LH)
(34109R) MN132370 1 Rear Diff Axle Seal (RH)
(34111) MA143517 1 Driveshaft/Diff Locking Nut 18mm
(34146) MB936390 2 Rear Diff Vent Plug
(34384) 4610A018 2 Rear Diff Bleeder Screw
(34385B) MT203641 1 Driveshaft/Diff Locking Nut 18.5mm
(34386E) MF140258 2 Rear Diff Support Bolt M10x20
(34386F) MF240023 4 Rear Diff Carrier Cover Bolt M6x12
(34395B) MF660036 2 Rear Diff Fill Plug Gasket 16mm
(34395C) MN130495 2 Rear Diff Drain Plug Gasket 18.2mm
(34397B) MR325595 2 Rear Diff Fill Plug with Gasket
(34397C) 3713A013 1 Rear Diff Drain Plug with Gasket
(34397D) 3713A029 1 Rear Diff Drain Plug with Gasket
Old Dec 7, 2016, 08:46 AM
4g63girl's Avatar
Just re-organized the Competition Clutch Parts.
It's now super easy to find and compare the clutch options and ALL the rebuild parts are easily laid out to re-fresh your clutch!
Shop at
www.STMTuned.com!
Competition Clutch Evo X Single-Disc Clutch Kits
5153-2100,5153-0100,5153-2600,5153-1620,5153-0620,5153-1420,5153-0420
Competition Clutch Evo X Multi-Plate Twin & Triple Clutch Kits
4-5153-C & 4T-5153-C
Competition Clutch Evo X Twin Rebuild Parts
TM7-1123 TM2-897-TSA TM2-897-TSB TM7-3 TM7-2 TM1-645-2B TM1-645-1B
Competition Clutch Evo X Triple Rebuild Parts
TM7-1123 TM2-897-TSC TM7-3 TM7-2 TM1-645-2B TM1-645-1B
Competition Clutch Evo X Twin/Triple Disc Throw Out Bearing
TM5-5106-TBA
Old Feb 23, 2017, 10:06 AM
4g63girl's Avatar
Genuine OEM Mitsubishi Evolution X Parts
Engine > Valve Cover
(01100A) 1035A810 Metal Valve Cover
Fits All 2008-2015 Evolution X
(01100A) 1035A909 Valve Cover
(01100A) 1035A999 Valve Cover
(01110) 1035A583 Valve Cover Gasket
(01115) 1035A836 Valve Cover Rear Hose
(01127) 1035A419 PCV Valve O-Ring
(01130) 1035A422 PCV Valve
(01191) MS660242 Hose Clamp (to valve cover)
(01191P) MS660220 Hose Clamp
(01198) 1035A572 Valve Cover Bolt
(01915) 1035A769 PCV Hose
(04903A) 1250A020 Oil Cap with 5w30 lettering
(04903A) 1250A010 Oil Cap without lettering
(04907) 1250A012 Oil Cap Gasket
4g63girl's Avatar
Wheel/Tire/Steering > Power Steering Oil Pump (37-110)
(10040) Part Number: 4451A115 Alternator/Serpentine Belt
Fits all 2008-2015 Evolution X
(14300) Part Number: 1345A052 Alternator/Serpentine Belt Tensioner
(48013) Part Number: 4450A124 Power Steering Upper Bracket
(48013P) Part Number: 1801A042 Power Steering Lower Bracket
(48055A) Part Number: 4450A097 Power Steering Oil Pump
(48058) Part Number: 4450A308 Oil Pump Pressure Switch Bracket
(48959) Part Number: 4450A309 Oil Pump Bracket Bolt
(48707) Part Number: 4455A252 Power Steering Reservoir Cap
(48736A) Part Number: MN101937 Power Steering Reservoir
(48821) Part Number: 1341A029 P/S Oil Pump Idler Pulley
(48959B) Part Number: MF140227 P/S Oil Pump Bracket Bolt (M8x25)
(48959C) Part Number: MF140023 P/S Reservoir Bolt (M8x16)
(48959D) Part Number: MF140244 P/S Oil Pump Bracket Bolt (M8x90)
(48959P) Part Number: MF140233 Tensioner Pulley Bolt (M8x40)
(48959Q) Part Number: MF241296 P/S Lower Bracket Bolt (M10x80)
(48959S) Part Number: MU001002 P/S Lower Bracket Bolt (M10x40)
(48970) Part Number: 4455A253 P/S Reservoir O-Ring
Old Feb 23, 2017, 10:07 AM
4g63girl's Avatar
Suspension > Front Suspension Arm & Member Diagram (33-050)
(32123) Part Number: 4000A125
Front Axle Crossmember Bar
(32156L) Part Number: 4000A193
Front Axle Crossmember Stay
(LH - USDM Driver Side)
(32156R) Part Number: 4000A194
(RH - USDM Passenger Side)
(32162) Part Number: 4000A124
(32166) Part Number: MU000671
Front Axle Crossmember Bolt (M14x80)
(32166C) Part Number: MF140423
Front Axle Crossmember Bolt (M18x16)
(40026) Part Number: 4000A123
Front Suspension Center Member
(40099B) Part Number: MF912108
Front Center Member Bolt
(40099C) Part Number: MU000765
(40311) Part Number: MR316449
Lower Suspension Arm Bracket
(40317) Part Number: 4013A456
Lower Arm Ball Joint Cover
(40320AL) Part Number: 4013A181
Front Lower Control Arm
(40320AR) Part Number: 4013A182
(40387B) Part Number: MU000763
Lower Arm Nut
(40387C) Part Number: MU000567
Front Suspension Lower Arm Nut
(40388B) Part Number: MU000467
Front Suspension Lower Arm Bolt (M12x60)
(40388C) Part Number: MU000611
Front Suspension Lower Arm Bolt (M14x80)
(40388D) Part Number: MU000546
Front Lower Control Arm Bolt (M14x90)
(40388E) Part Number: MF241282
Control Arm Bracket Bolt (M10x25)
cficare68
Dec 21, 2017 08:39 AM
4g63girl
Mar 29, 2017 12:38 PM
4g63girl
Mar 9, 2017 09:17 AM
badev0
Feb 1, 2017 06:01 AM
STM Tuned
EvoX 'For Sale' External Engine / Power
Jan 7, 2015 08:17 AM
Quick Reply: Evo X Product Updates and Additions at STM
