WORKS short-shifter and shifter base bushings installed (Evo X)
#77
Got my Works shifter, Works under the shifter bushings, AMS under the hood shifter bushings and AMS gate Selector Bushing kit. I am loving the way everything feels. It is a huge improvement over stock that I should have made along time ago. Probably before I did any of my other bolt ons.
#78
I did the under the hood bushings and gate Selector bushing first. I think the shifter base bushings had the biggest impact on stiffening up the shifter feel. They are actually what goes in between the shift cage and the chassis. They don't replace any bushings that attach to linkages under the shifter.
#79
I'm looking into doing this mod after my clutch and girodisks. I'm curious if you think the Kracka package with the TWM cage is worth it or would I not be able to tell the difference adding the cage?
Thanks
By the way, I'm thinking about going with metal bushings. When people say they make noise, what kind of noise are they talking about and when does it occur? Only when shifting?
Thanks
#80
Thanks
Thanks
#81
I went with metal everything. I don't think I hear anything but then again the car is pretty loud and worrying about noise on an Evo seems odd to me. The twin clutch clank and chewbaka sound drowns out other noises anyways. The exhaust cutout takes care of everything else.
#82
Just installed my works short shifter with their base bushings. I managed to install the base bushings without having to install them upside down. The shifter install wasn't to difficult but those bushings were a pain at first. The trick for me was too slide the poly bushing into position underneath without the metal insert attached. then I pushed the shifter cage down to pop the bushing in. Just use your finger or a screw driver to line the bushing up through the hole before you bush it down.
#83
TWM Performance
Feb 28, 2017 07:36 AM
TWM Performance
Lancer Tranny/Drivetrain Tech
Feb 28, 2017 07:18 AM
TWM Performance
EvoX 'For Sale' Engine Internals and Drivetrain
230
Aug 26, 2016 01:16 PM
1fastvet
22
May 23, 2016 07:40 PM
