MAP REV 3 IM and MILSPEC 65mm TB upgrade
I am posting this review as an FYI for those looking to use these parts as a power mod. The information provided is basic and factual, gathered information from my old, during, and new dyno graphs and data sheets. This is not the most technical post, put gives a good general concept. All dyno numbers were on the same mustang dyno at the same shop by the same tuner. The old numbers are done on 91 octane in September 2008 at about 80*. The new numbers are done on 92 octane in January 2012 at about 58*. There was about a 22* difference (warmer in '08). I don't remember one day being more humid than the other. If it was significant, I would have remembered!!. I always change oils, run injector cleaner, and change spark plugs before each tune. Here it goes:
MODS and numbers before adding MAP REV3 IM/ MILSPEC 65mm TB:
EcuTek via MZM 345hp @ 7367 rpm, 278 tq @ 6048 w/ 91 octane @ 22psi
Apexi RX6 turbo kit, Tanabe Concept G blue 3" TBE, Greddy 720cc inj, Perrin fuel rail, ETS 4" IC kit, 272 HKS cams, Hallman Pro RX MBC, Walbro 255 lph Fuel Pump, HKS SSQV, Sun Auto Cyber Speed HVS & Ignition box, ACT HDSS, Agency Power side & lower motor mounts, Shep transfer/x-mission
Same MODS plus MAP REV3 IM and MILSPEC 65mm TB before tune:
EcuTek via MZM 327hp @ 7178 rpm, 267 tq @ 6161 w/ 92 octane @ 22psi
Same MODS plus MAP REV3 IM and MILSPEC 65mm TB after tune
EcuTek via MZM 355hp @ 7149 rpm, 293 tq @ 5993 w/ 92 octane @ 24psi
Above are the basic results. Upon installation, I lost 18 horsepower and 11 torque, but gained spool. After completion of the tune, I gained 28 hp and 26 tq over baseline with even quicker spool. My peak gain over the old tune was 10 hp and 15 tq. The gain you do not see is my power curved smoothed out and hold to redline. my old graph lost power as I got approached redline and top of the curve looked like an EKG! With the addition of the IM/TB, my power is strong and holds to redline with minimal bumps in the curve, giving me more useable power.
I know there is alot of technical data some of you big time tuning gurus would like to know, but I do not have all the info. This is not intended to sway any decisions, just give basic information for the common guy. Hope you enjoyed!!
I found it strange I lost power initially as well. Again, many unknown variables.
basically what i'm saying is we need a full before/after dyno sheet to call if its a worth while mod, not just peak numbers...
Here is the dynograph. I did not get a colored copy, but the gains are easy to see. Hope this answers more questions.
and seeing rpm would be nice...
and is it just me or is hp really low for all those mods?
