Vendor Service / Parts / Tuning Review Post your service, part & tuning reviews here. Please note all new threads are moderated.
TRE: transmission Billet Oil Cooler adapter/Saviour of 4th Gear
Old Jun 27, 2014, 09:14 AM
mrfred's Avatar
Originally Posted by powerdriver
yes and no. this has two outlets to install a cooler.
With a large enough cooler/fan and pump, you'll never have heat issues.
If it has inlet and outlet, then I want it for the 6-speed.
Old Jun 27, 2014, 09:19 AM
ryukinevo's Avatar
Where would you mount this transmission cooler if you have a ACD pump and what size are the lines?
Old Jun 27, 2014, 10:10 AM
powerdriver's Avatar
I'll have to call Jon and ask him those questions. The ACD shouldn't be in the way at all... you have a good 6" between the cover and the pump.
Old Jun 29, 2014, 03:16 PM
EvoIIIAj's Avatar
Very interested in this also as I just got a 5 speed rebuilt with Buschur.
Old Jun 30, 2014, 06:30 AM
"It comes with stainless plugs but I have stainless fittings that have male -6AN. They are HD and have a PTFE seal that seals them up and helps lock them in place in high vibration applications."
"The hole size is 3/8"-18 tpi. I have -6 AN fittings available too."
As far as fitting sizes for the plate is concerned.
Old Jun 30, 2014, 01:40 PM
ryukinevo's Avatar
I am definitely buying this part ASAP my evo gets out of the shop.
I was misunderstood that you need a pump and oil cooler for it to work. That is for cooling the oil. This is an upgraded part to factory plate to splash oil for 3-5 gear.
Thanks Jon for taking the time to give me a call, great guy with great parts for our evos!
The plan is to buy this part and figure out how to mount the pump/transmission cooler after its installed!
Old Jun 30, 2014, 05:41 PM
antilag_200's Avatar
Jon will take care of you. He is a wealth of knowledge
Old Jun 30, 2014, 05:45 PM
EvoM Community Team
golgo13's Avatar
Nice piece, couple of questions though.
Does this thing collect old fluid? Does it have a drain? Do I need to remove it each time I do a fluid change?
Old Jun 30, 2014, 10:08 PM
Does it collect old fluid? No such thing as old fluid. It all gets worn down at the same time.
Does not have a drain unless you're talking about the inlet/outlet, even still it won't drain out all the fluid.
You do not need to remove it each time you do a fluid change.
It's an upgraded version of the factory oil splasher.
Old Jun 30, 2014, 10:28 PM
EvoM Community Team
golgo13's Avatar
Here's what Jon had to say:
Originally Posted by GEARS
Golgo13!
Not really but there are some small passageways and a 60/30 micron dual element stainless steel screen which serves as a filter to keep any metal fragments from passing through the auxiliary pump and heat exchanger.
No it does not have a drain. You can remove the "OUT" plug to drain the residual oil that the unit holds but it'll only be a few ounces.
No but once a race season or every year would be wise.
Jon
Old Jul 1, 2014, 07:16 AM
pfunk47's Avatar
Thanks for posting this Waren and thanks to Jon for developing this. For anyone with contact issues I sent him an email at 12am last night, he responded within the hour and the part is paid and being shipped out this morning. Any leads on a pump that will work for our application?
Old Jul 1, 2014, 07:19 AM
EvoM Community Team
golgo13's Avatar
You guys from Michigan need to stop pimping this as its quite suspicious.
Old Jul 8, 2014, 05:03 PM
awdboosted's Avatar
I've been running a TRE Billet transmission cooler adapter for almost 1.5 years now. I currently road race my Evo about 4-5 times a year. Even without a heat exchanger installed on this, I can say the trans shifts consistent and feels strong. Even after repeated hot laps around the track. I also installed the inspection plate cooler for the Transfer case. That rare earth magnet picks up everything and because of the o-ring design, I call pull it off with ease and clean it with every fluid change.
I also added a temperature probe to see what the temperature is. I've been seeing on average 245-255 trans temperatures. After seeing that high of a temperature, I'm planning on putting on a cooler to get the temperatures down and protect the gears; especially the 4th gear.
This is by far worth every penny.
Attached Thumbnails TRE: transmission Billet Oil Cooler adapter/Saviour of 4th Gear-12.jpg   TRE: transmission Billet Oil Cooler adapter/Saviour of 4th Gear-17.jpg   TRE: transmission Billet Oil Cooler adapter/Saviour of 4th Gear-9.jpg   TRE: transmission Billet Oil Cooler adapter/Saviour of 4th Gear-1.jpg   TRE: transmission Billet Oil Cooler adapter/Saviour of 4th Gear-15.jpg
Old Jul 8, 2014, 08:15 PM
mitsubeastlee's Avatar
I need this.....
Old Jul 9, 2014, 03:08 PM
ryukinevo's Avatar
I am trying to get the hook up figured out?
Did you install the pump and transmission cooler with an lines somewhere, I do not see it in your pictures?
Would there be any reason to install a temperature guage on the transmission, what can you do about the high temperature if you do see it, just stop driving it to cool off or what?
Quick Reply: TRE: transmission Billet Oil Cooler adapter/Saviour of 4th Gear
