What sealant is meth resistant?
So I'm installing a low fluid switch in a custom tank, & was wondering what is the best sealant to use? Urethane? Silicone? A permatex product?
Thanks!
Thanks!
If you haven't yet purchased the level switch, you might like to consider this one:
http://www.aquamist.co.uk/sl/plist/p...1/806-281.html
It comes with a EPDM gasket (alcohol resistant). The gasket expands when you tighten the nut and seal the 22mm hole. External fitting.
If you have problem making a seal outlet from a plastic tank, this fitting will help you to do it effectively: (you might need to register):
http://www.aquamist.co.uk/phpBB2/viewtopic.php?t=765
Thanks EVE-SLOW! This is going to seal a lid onto the container, so it will not ever be submerged in Meth, but will be keeping it sealed and get splashed with meth all the time.
LanEvoNine
Jan 22, 2006 11:24 AM
