My Aquamist HFS-5 Install Guide
Below is a link to my HFS-5 install guide. Please read this guide if you are considering installing and HFS-5 or HFS-1.
If you find any errors or revisions that need to be made please PM me about it.
Hope it helps.
GUIDE
(Note - this is a large PDF document; might take a while to load. Consider RCSA method.)
Hope it helps.
GUIDE
I have started looking through the picture files, so many great images to go through. I will enjoy reading your install manually the moment I get some time, There will be pages and pages- I will start later on tonight.
Richard
Richard
I have read the entire guide, it is brilliant !!!
I have just updated the HFS-5 user manual (inspired by you) for anyone who needs an update (v3) Click here:
Thanks for the guide. It was very helpful.
FWIW I use my OEM WWF container with great success. I mix my own 50/50 and spray it on the windshield too.
Ever thought of adding that bit of info into your guide?
I will show you a couple:
from a LGT though
Here is the tap in the TMIC (I now have two jets)
This is also from my Perrin PWI-1 system I installed (c/w DDS-3 gauge), but later changed to the HFS-5 for flow.
FWIW the Aquamist "race pump" is better IMO at regulating flow. The HSV does a good job, but not as good as the HSV.
If I was less then 320 whp I would have kept the Perrin system, but I was able to get a bit more out of my car with more alky, so the Perrin one is sitting in my garage.
from a LGT though
