Best Failsafe for AEM Meth Kit?
Old Jun 7, 2008, 01:40 PM
90GSXDan's Avatar
I was wondering what would be one of the best failsafes to run with the AEM meth kit, as I have now ordered my kit and I need some good defense for a failure.
Thanks!
Dan
Old Jun 7, 2008, 03:52 PM
Richard L's Avatar
The Aquamist DDS3 will work with AEM WAI system.
Upon fault detection, it can switch map or lower boost even you remove the power feed to it.
List of possible faults covered by the DDS:
- clogged nozzle
- low flow level (user defined)
- cut hose
- high flow level (user defined)
- loss of power supply (very important requirement for any failsafe system)
- Severed cable between the DDS3 and the BCV
Now supply with "push-fit" fittings for 1/4" OD hose as standard.
Old Jun 7, 2008, 05:24 PM
90GSXDan's Avatar
Where can I purchase this from directly? And How much?
Thanks!
Dan
Old Jun 8, 2008, 01:28 AM
Richard L's Avatar
The dealer below often carries good stock of it.
RallySport Direct
Subaru and Mitsubishi
14881 Concord Park Dr #1
Bluffdale, UT 84065
TEL: 801 748 4910
FAX: 801 748 4911
Email: parts@rallysportdirect.com
Web: www.rallysportdirect.com/shop/
Or shop around from other dealers:
http://www.aquamist.co.uk/sl/plist/frm-4-USD.html
Old Jun 8, 2008, 06:50 AM
90GSXDan's Avatar
Now Im not trying to start an arguement, but I would like Labonte to chime in.
What makes the DDS3 better than the ISF-10 with the BBK-10? Besides the flow gauge...
Just trying to look around before I dump somemore money...
Dn
Old Jun 8, 2008, 08:40 AM
Richard L's Avatar
I don't know ISF-10 enough to compare but I will look into it.
One good feature of the DDS3, if the unit itself fails due to loss of power externally or internally, it will put your engine into a safe mode by default.
Old Jun 9, 2008, 11:51 AM
90GSXDan's Avatar
Any info? Any word from Labonte?
Thanks!
Dan
Old Jun 9, 2008, 12:01 PM
ElectricEvoIX's Avatar
subscribed for more info
Old Jun 22, 2008, 09:10 PM
Labonte MotorSports's Avatar
Dn
Can't really comment on "better" since there are always different view points on it.
We do offer a Flow Gauge option for our Fail Safe, IFG-20 or IFG-30. Shows a numeric value rather then a bar graph and recalls last Peak injection rate.
More info here:
http://www.labontemotorsports.com/st...onitoring.html
Simple and less wiring to install the IFS then other units. It is the only unit on the market that is designed to be installed in the engine bay of the vehicle.
Best regards,
Dan
rado
AEM EMS
Oct 17, 2016 08:29 PM
alexis21
Feb 22, 2016 05:20 PM
legacydestroyer
Oct 12, 2015 07:45 AM
legacydestroyer
Sep 13, 2015 06:17 PM
TheBoz
Dec 25, 2011 05:39 AM
Quick Reply: Best Failsafe for AEM Meth Kit?
