reliable easy to tune ethanol injection is best way to go
I am only using one hobbs switch to trigger the two relays. One relay runs the fuel pump. The hella relay drives the injectors. The hobbs triggers at 5psi. I would have to look at my map to see where the trigger is concerning load lines. Tune wise its impossible to get the transition A/F perfect. The ecu averages neighboring cell values. So at the point where you tell ecu to go leaner (5psi) the next lowest load line will be effected as well so the curve goes lean for a split second. Driving the car I cant tell. The transition is seemless. in the dyno graph you can see during spoolup right were it heads lean (hump at 3400rpm)
One relay powers up the pump and injectors, while the other (iassume its grounding...could be powering) is triggered cyclically by the primary injector pulse to control the secondaries. Now that I think about it...I wonder how the current load to trigger the relay coil effects the injector(s) that it's triggered off of...Im not sure it's significant enough tho...
The hella solid state relay doesnt draw any significant power from main injector pulse. The input trigger side of relay is photo optic. so its lightening fast and draws no significant power. the output side is rated at 32 amps. so it is loafing driving two or four injectors at about 1.5 amp each. I have a second more powerful car setup using four injectors using the same circuit. I only spent about 45 minutes dialing in that fuel curve you see on the dyno graph. its not really optimized at all. havent touched the tune since the setup went on.
I have thought that ideally you would want to use two hobbs switches. set about 2 psi apart. turn fuel pump on first so fuel pressure on rail is always same. I know from simple tests I have done secondary rail is not maintaining any rail pressure. but when you turn system on at low psi its not so critical the a/f is sloppy at transition. It does become far more important when injecting larger amounts. my other car turns four 880s on and I am having a hell of time getting it to transition smooth.
