Aquamist kit options + SD
After doing some research I would still like to know which kit to go with ( hsf3- hsf4) as after emailing Richard at aquamist, I was told those are the only two kits in production. Should I try to track down a hsf6? While running 30+ psi on the hta35r kit i was planning on a 50/50 mix if this is correct. The last debate is where i should install the nozzle if I am also running speed density with the buschur uicp. Some say 12" from the tb, whereas others say right after the intercooler. Thanks!
Have you read through the user's manuals of both? What do you want the kit to do? I think that most would do what you want, but the 6 just gives more control. The HFS-3 and 6 can be found from $500 used.
What did Richard say about the nozzle? The more time the liquid has to integrate the more of a temp drop and the more uniform the liquid will be, unless of course you have some good bends in there.
blacktab420
Feb 2, 2016 09:51 AM
LeXcite
Aug 2, 2014 05:56 PM
Khankn32
Apr 18, 2014 08:19 AM
