rapid cylinder wear w/pics again
Old Nov 4, 2016, 07:32 AM
  #31
94AWDcoupe's Avatar
Originally Posted by 2winscroll
If you knew anything about reading carbon traces, you would know. Smooth carbon ok, sandy pitted carbon bad. This motor probably had to much timing in the low to mid load ranges causing mild detonation. The upper ring land has scored at the very top of the cylinder, you can see the scoring only at the top, classic of mild detonation.
Bringing it back so people can learn something, and be properly informed. Hopefully your open minded, Consider yourself schooled.
I dint learn anything from what you say. cause its simply not correct diagnosis.. These engines are not run with detonation. My ecu on this car monitors the knock signature on all four cylinders. and i get to see it in the logs. this is something the evo 8 ecu doesnt even have. beyond that I know what detonation damage looks like when you take an engine apart. and thirdly even if there was long term detonation it would not smooth the cylinder walls out. VW engines from the 90s literally run 100s of thousands of miles with audible light throttle detonation. they arent wearing out cylinder walls.
Old Nov 7, 2016, 04:09 PM
  #32
RightSaid fred's Avatar
Your knock detection doesn't work correctly.
Just because it'll pick up heavy knock under false conditions doesn't mean it'll pick up light knock under real conditions.
Water injection works best when its just water.
If you want to use methanol as well, put it in the fuel tank.
Have you ever thought about what happens when you use pure methanol in the water injection tank and you hit the rev limiter several times?
I'll give you a clue, a lean mixture of methanol/ air is prone to pre ignition.
Knock detection doesn't pick up pre ignition but pre ignition will go on to cause knock if it 's allowed to go on uncontrolled.
Old Nov 8, 2016, 04:34 PM
  #33
94AWDcoupe's Avatar
another completely useless post
Old Nov 20, 2016, 08:20 PM
  #34
94AWDcoupe's Avatar
It's beyond your comprehension.
I built my first turbo car in 1990. it used water injection as only source of charge air cooling. The engine ran for 35,000 hard miles and was sold in perfect running condition when I decided to build a larger engine. i have been building turbo charged cars for most of my life. Most all of them used secondary injection of some sort. I have used virtually everything on the market. YOU HAVE NO IDEA who you are trying to educate. your vain insults will get you no where.
In short go away. unless your intention is to make me laugh
Old Nov 21, 2016, 12:47 PM
  #35
2winscroll's Avatar
If you already know everything why are you asking for opinions then?
Pitted carbon+Upper cylinder scoring usually means deto/pre ignition
If it were to much fuel there would be no carbon at all, Pistons would wash clean around intake area.
Just saying
Old Nov 22, 2016, 05:58 PM
  #36
94AWDcoupe's Avatar
your reading comprehension sucks too. where was I ever asking a question? I am just sharing what I have learned with using methanol injection for 30k miles on two different engines. dont really care if you "get it". the information may be useful to those who do.
Old Nov 23, 2016, 03:03 PM
  #37
Bore wash is caused by too much fuel at low load.
In turn caused by hotwiring the fuel pump, then it over runs the stock FPR.
Fuel pressure at idle is out of spec, fuel trims change to try to compensate but it's still too rich.
Looking at the plugs tells you everything you need to know.
Old Jan 12, 2017, 12:35 PM
  #38
LetsGetThisDone's Avatar
Received 1,543 Likes on 1,322 Posts
Why are you not banned yet??
Old Jan 12, 2017, 04:38 PM
  #39
Klaiceps's Avatar
I think we need to start reporting his posts.
Old Jan 12, 2017, 05:02 PM
  #40
I was, moderators PM'ed me and said they were "dealing with it".
Old Jan 23, 2017, 08:16 AM
  #41
EvoM Administrator
Nsomniac's Avatar
All posts in this thread were made prior to any issues being addressed.
LetsGetThisDone (Jan 23, 2017)
Old May 28, 2017, 09:06 PM
  #42
barneyb's Avatar
What the author writes about low power engines surviving a long time detonating or even designed to detonate interests me. I once worked at a place that had an S-10 Blazer that I was often given to drive out of town to various meetings.
That thing would ping and sound like hail on a metal roof any time you put your foot into it and you had your foot into it constantly if you wanted it to move. On the highway it would rattle itself up every hill. During the few years we had that truck I don't remember it having engine trouble.
94AWDcoupe
44
Nov 6, 2017 08:40 AM
94AWDcoupe
92
Feb 18, 2017 08:17 PM
94AWDcoupe
Jun 9, 2016 11:06 PM
94AWDcoupe
Jun 9, 2016 11:05 PM
94AWDcoupe
19
May 1, 2016 08:44 PM
Quick Reply: rapid cylinder wear w/pics again
