Tephra switching maps with HFS-3 , Ecu pin 64 ??
Hi guys ,
I am currently installing my HFS-3 kit on my evo 9 and it is about 80% completed .
I used the wiring diagram that Richard sent me , and I want to run a dual map setup with Tephra as a failsafe .
My problem is with the white wire use for the alt-map . Diagrams says to use the ECU pin 64 , but there is nothing at all in this pin .
Buying new pins and get that wire in there is the only way to go to make this setup work ???
Fortunately , SpoolinUp have new pins in stock , but it seems a PITA to get a pin in the oem harness ....
Thanks !
Thanks !
Okay , I ordered some pins from SpoolinUp and i got this thing done in a few minutes . It was pretty easy but still a bit stressfull when working one the ECU wiring and tiny parts such as ecu pins .
Now , I just have to wait to get tune to see if it is working .
Alchem1st
Mar 15, 2022 08:47 AM
