Ideal AFR on Water/Meth
I searched a lot but I didn't found any discusion about the AFR on meth injection.
I am running around 12.2 with good results but I would like to know any other members AFRs to compare with mine.
My results Stock IX turbo 30psi, Injen IC pipes, TBE and 50/50 AEM 1000cc
410whp
Timing goes around 7k is 19degree
Has anyone else more aggresive timing and AFR on meth?
410whp
Wouldn't you benefit more from increase timing compared to leaner AFR's?
Edit: I just notice your timing is 19 up top. That's usually the most I have seen or heard of anyone running. Not bad results with the stock turbo
Hybrid boost control..
Grimspeed + MBC
I am running 32psi peak boost but around 6000k is 26psi... and after that rpm less and less and less :/
I cannot find a way to keep boost at high rpms
Grimspeed + MBC
The stock turbo will not hold much more up top one of the trade offs to being a great street turbo.
If you have pushed as much timing the car will take and leaned it out as much the car will allow without knock then you are at the max. But at times it's pretty to sway to a little conservative just in case
<p>Yes I think that I cannot do something more.. </p><p>And everything after that is expensive..</p><p> </p><p>I find in good price tomei arms turbo second hand..</p><p>And with a bigger intercooler will be my next upgrade but I don't know if its worth the tomei turbo!!</p><p> </p><p>I wish to find a fp red in good price but there isn't something here..</p><p> </p>
KevOVIII
Dec 20, 2008 12:48 AM
