Help
Old Oct 22, 2004 | 05:14 AM
mitsubishimanny's Avatar
Help
no is replying to my post in the how to forum so i have no choice but to post it here and hope for some good replies before it gets moved. anyone out there with the 04 ralliart have any idea how to re adjust the headlights? i bought some nice aftermarket bulbs and snapped them in but now the alignment is off and i cant figure it out. anyone else done with? how did u align them little bastards?
Old Oct 22, 2004 | 06:02 AM
sillypuddy's Avatar
if you didn't move the actual housing the light shouldn't be misaligned unless you got some cheapo bulbs
i would make sure that you got it in the socket seated correctly.. my friend did that once and it was pointing skyward, it wasn't in the socket all the way
-joe
Old Oct 22, 2004 | 09:32 AM
turbonutter's Avatar
I don't have a Lancer (yet) but shouldn't there be some adjusting screws around the outside of the headlight bodies?
Old Oct 23, 2004 | 11:58 PM
bigdoggy_dog's Avatar
I was thumbing through the owners manual today and in the headlight section they talk about adjusting the headlights. Check it out and see if it's any help to you.
Old Oct 24, 2004 | 12:48 AM
ha ha, I do have a Lancer now (I've had it for about 4 hours as of this writing) but I haven't looked for the adjusting screws yet...
Old Oct 24, 2004 | 06:37 AM
pabboost's Avatar
the adjusting screws are on the headlight. jus tlook very closely
Old Oct 24, 2004 | 01:52 PM
Mitsuracer27's Avatar
I have the same problem...switched my bulbs to the silverstars and everyone tells me my right headlight looks less bright, I think it's just out of alignment. So hard to get your hand down in there to see if it's seated properly. When you look at the reflection off of another car it does look lighter. But doesn't seem to be so off that it effect's night driving. That's why I don't think it's the actual bulb, just distorted a bit (not seated perfectly flush). Think I'll take it to the dealer just to see if they can tell (they can tear up their hand trying to get in there).
Old Oct 25, 2004 | 12:42 AM
thanks all
hey thank you guys for replying with these tips. i just basically went and played around with the light bulbs a little more. im guessing it wasnt seated properly. i took them all the way and put them back in and made sure that they were all the way in. they aligned pretty much right on. thanks again.
Old Oct 25, 2004 | 08:16 AM
Good to hear, it's something the rest of us should keep in mind if/when we change lights in the future.
Old Oct 26, 2004 | 05:46 AM
sillypuddy's Avatar
told you so =) i had the same problem with seating them properly
-joe
