My Dirty Lancers!!
#91
Oh and Ive seen your car on jacks at all four corners. Do you feel there is any safety concerns with the entire car lifted? I got into this debate with some friends and family before. They swear its unsafe and unstable. I say just the opposite. Its planted on on solid, flat surface, and if its going to be left that way for a while your not putting extra stress on either the front or back suspension for long periods of time. IDK just wanted to see what your thoughts were since I know youve done it.
if you're concerned about teh car being on 4 stands like crans said.....just stick wheels underneath or a jack(to help support, not to hold all the weight...that's the point of the jackstands) so IF it failed in some catastrofic way and the jackstands are no longer under the car, it doesn't just fall to the ground(aka on you), but ontop of the wheels leaving you @ least soem room to try and wiggle out and/or wait for help
UPDATE:
no pics, but the transmission is back together. I was going to rob the other transmission of all the gears that were better than mine and build up one set of good shafts, but then I said screw it and just replaced one diff bearing, and the one output shaft bearing that is pressed into the case. Got my flywheel resurfaced today, hopefully I can get the clutch and transmission mounted tomorrow. at least I don't work tomorrow I should be able to make good head way. problem is I'm working out of someone else's garage, and time is not on my side.
it's not a show queen, right?..lol
#93
great progress man! i hope everything turned out well and that beast gets back on the road asap. its just amazing how you can do all of that by yourself. wish i could do that lol...
#96
so basically, I swapped my own transmission into the new case...some of the gears were in better shape than mine, in fact, all the gears that looked perfect in the donor transmission were not so great in mine, and all the gears that looked not so good, were much better in mine...I basically could have made a perfect transmission, but I've opted to donate the output shaft to rzrxn, and then i'll rebuild his output shaft and the spare input shaft for myself...that IS if I can get my original case repaired...if not i'll store the shafts in a bag of oil for whenever I need them again.
here's the "new" tranny...I would have cleaned it up, if I gave a ****, but...yeah. It's my old case, and my old shafts, and the Quaife with only the new bell housing/differential case swapped over. The amount of spare parts puts a smile on my face
notice the new rear roll stopper bracket? the donor transmission came with one, but I broke mine in half, and bought a new one long before the clutch failed...I used the brand new one out of principle.
Here's the flywheel torqued and clutch aligned...didn't take pics of the pressure plate installed, cause I doesn't look any different than my old one, lol...
likei said, the transmission is already installed...just need to reinstall my axles, fill her up with oil, and reinstall the charge pipe for the turbo, do an engine oil change and she'll be good to go...
#97
wow...just wow...congrats on this man! and thank you for the kindness...you know how bad my trans is loool! i'm happy for you though...the beast is finally back on the road! and it's getting warmer so it's perfect timing
#101
Due to the transmission being driven with no oil in it, there was some wear on the gears, which is causing some gear whine, but mechanically it is smooth, shifts like before, and the clutch is VERY grabby...it doesn't slip at all, even if you rid the pedal...it's on or off, but the sprung hub alleviates a lot of the harsh engagement...i love it.
oh yeah...happy to have her back...took a bit to get used to after driving the Mazda 5 for so long.
#102
But Im sure it felt good to be back in the RA. :3
#103
@Garrett: cheeeers man! that's awesome. now she's just about ready for the shootout this year right? i'm definitely planning to go this year and i really hope i get to make it. i was supposed to go last year but things got tight and i wasn't able to make it. i'm happy for you man. your RA is back and ready for some action! now all you need is a gaming rig setup in your RA lmfao! i'm not giving up on that yet...
@Josh: i think you should go right into your turbo build and do as much maintenance as you can on the engine. that would be a pretty awesome project! and plus, Garrett is here to help you if you get into any snags along the way. his turbo build thread is an amazing read. *chanting* DO IT DO IT DO IT!!! looool...
CrAnSwIcK
Jan 8, 2015 02:20 PM
CrAnSwIcK
119
Oct 14, 2013 11:25 PM
CrAnSwIcK
16
Aug 14, 2013 06:50 AM
CrAnSwIcK
24
Jun 22, 2012 10:48 AM
