xmaster's PW 04 RA
my release bearing is shot too..my tranny needs a lot of work done..it's just that money is so damn tight right now..school is killing me..osap isn't helping me at all..my courses are so expensive..but i'm really trying to put away funds for a rebuild..little-by-little i should get there soon..
This is what the crossmember looked like...
It was almost broken in 2. The effect of the new cross member on the car is truly amazing, the car never felt so tight since I got it.
On the list is : Steering rack, suspension and bushings, one ABS sensor.
Buuuuut, when that is done, I will start modding the engine, first will be intake mods, Endeavor TB, PnP intake manifold. At this point I would like to get a 2nd engine, tear it apart and slowly fully rebuild it. High compression pistons, stronger rods, 4G63 valvetrain, new seals all around, the whole deal, but N/A if the plan doesn't change by then. I'd like to track the car and would hate to be the slowest :P.
The way I see it, I will keep the car for a very long time. At minimum 5 years, so I have to keep it road worthy!
Thanks!! Well my plan is mainly bringing the car back to factory spec or better first, so repairs/maintenance go first. I upgrade as soon as it's possible, but will keep on prioritizing repairs over mods.
Anyways, who wouldn't want a 260hp(stock 3.8) RA with V6 awesomeness?
Until then, the V6 seems like a relaible way to make power. Like you said, pushing a powertrain over it's designed limits can be troublesome.
The V6 puts out 260hp stock, the 4G69 is far from that number. In my mind, a V6 with headers and a CAI will always be more reliable than a turbocharged 4 (not from factory).
Anyways, by then, I'll probably change my mind about the whole thing 73 985 times. We are talking about 5-10 years down the road, I'm not even sure the car will still exist!
Go for it, and good luck with your rods :P
In my world, easier usually means less desirable... yeah I'm ****ed up like that.
Piece one yourself.
The engine is the same, the management of the engine is almost the same, the automatic tranny is bigger than the 5 speed so you might have less room to play with. You will also have the trans oil cooler in the way, gotta find a way around this. Electric pusher fans might save some space behind the rad.
T3/T4 turbos are inexpensive and easy to find. The manifold should be the same, unless it angles the turbo towards oil cooler lines. Even if it does, the manifold can be modified by any welder or muffler shop.
Piping is easy to find, you just have to know where to look. Ebay might even do the trick, but don't try to jew it too much on this part, you will regret it.
The ECU part might be trickier, but you could pull it using a piggyback, not the best option but still proved effective on many other cars. Not sure if Hackish has a A/T reflash, you could look into that also.
Can't say I haven't thought about it for myself.
think a DOHC 4G69 high compression build would be awesome, you should do that one...
This got my interest, I'll try to look into this.
I guess I'll have to find a 4g63/64 head gasket and a 4g69 one also...
no i was considering a straight up 4G63T MIVEC swap, lol...but then i was looking at the prices of Evo 9 block/heads...and it dawn on me that i could build a turbo kit for much less...
though the 4G63 head on a 4G69 block is quite interesting...it bolts right up, there's no magic...it's the control harness/ECU that's the tricky part, so i would say it's probably easier to put a 4G69 block in an Evo, than to put a 4G63 head in a lancer Ralliart...
Yeah, evo9 heads are probably very hard/expensive to come by....
Still worth giving a shot, I believe.
Think of a DOHC Mivec 4G69, that sounds desireable. Drop HCR pistons in there and we have something worth putting together, I guess!
