04-06 Ralliart Aftermarket Forced Induction Tech (aftermarket turbo/supercharger related topics)
Racer Xs Turbo Build
Old Jan 30, 2015, 04:13 PM
  #136
CrAnSwIcK's Avatar
Originally Posted by RacerX-Ralliart
I paid the turbo tune price a long ways back
oh ok...then you should be good...what injectors do you have?
Old Jan 30, 2015, 07:02 PM
  #137
RacerX-Ralliart's Avatar
I have 600cc injectors off a subie that I got off eBay but I might just get the 440s to make things easier..
Just ordered the head studs yesterday and they are already here!
Old Jan 30, 2015, 10:04 PM
  #138
Engine out!
Old Jan 31, 2015, 09:53 AM
  #139
CrAnSwIcK's Avatar
Engine out!
how the heck are you going to get that out of there??
Old Jan 31, 2015, 11:37 AM
  #140
Lol I need to lift the car up higher! And tilt the engine a bit
Old Jan 31, 2015, 02:33 PM
  #141
CrAnSwIcK's Avatar
lol...I don't have a cherry picker myself either, but I would borrow one...good on you though
Old Jan 31, 2015, 05:34 PM
  #142
bakuro117's Avatar
LMAO thats what me and Nekkiidlad did to get the engine out of the green RA. We realized we wouldnt have room to lift it out so we set it on the ground, then lifted the car and slid it out on an old piece of carpet. LOL
Making quick work! Keep it up man!
Old Jan 31, 2015, 06:28 PM
  #143
Hahaha bakuro yeah I set mine down on a furniture dolly and rolled it out... Wasn't as easy as it sounds though cause after I undid the lift I noticed that two of the wheels are fixed so I had to lift and drag to get it out!
Found the balance shaft belt just stuffed in between the crankshaft and I think that's what cause this failure
Old Jan 31, 2015, 08:35 PM
  #144
CrAnSwIcK's Avatar
that'll do it...hope the damage is minor...let's open that thing up!!!
Old Feb 6, 2015, 08:09 PM
  #145
I borrowed the bearing heater from work and decided to put the bearings on the LSD. first bearing went on like a glove I love this thing! I jumped the gun on the second bearing and it only went half way down haha so I'm taking it to work tomorrow to use the bearing press. I'm not sure if the speed gear is supposed to sit all the way down though because there is so much more surface area above it. Head gasket came in today, and engine will be here Monday just wanted to update you guys
Attached Thumbnails Racer Xs Turbo Build-img_20150205_191033.jpg   Racer Xs Turbo Build-img_20150205_191159.jpg   Racer Xs Turbo Build-img_20150206_185705.jpg   Racer Xs Turbo Build-img_20150206_185716.jpg   Racer Xs Turbo Build-img_20150206_185834.jpg
Old Feb 6, 2015, 10:25 PM
  #146
CrAnSwIcK's Avatar
is that a wavetrac? also, on my quaife, the speedo drive gear left a similar gap...
Old Feb 7, 2015, 04:02 PM
  #147
Yeah its a wavetrac, I wonder what the differences are between the two
Old Feb 8, 2015, 07:33 AM
  #148
CrAnSwIcK's Avatar
other than the "wave gear" in the center, nothing...
Old Feb 9, 2015, 07:32 AM
  #149
Got the transmission apart, and put the final drive gear on the LSD. Going to soak it in some mtl before putting it in, but I think I'm going to need to remove the outer race from the case because it moves around and I don't think its supposed to because its a pressed fit..
Attached Thumbnails Racer Xs Turbo Build-img_20150208_203840.jpg   Racer Xs Turbo Build-img_20150208_203850.jpg   Racer Xs Turbo Build-img_20150208_205059.jpg
Old Feb 9, 2015, 10:49 AM
  #150
CrAnSwIcK's Avatar
make sure you use red loc-tite on the final drive bolts, also you best use the outer races that came with the respective diff bearings in the case...
Quick Reply: Racer Xs Turbo Build
