Racer Xs Turbo Build
#167
Got the head off this past weekend, been really busy with work and stuff around the new house. Also got the transmission together a couple of times with the spacer in place I was able to get the preload to .1-.2 mm. Going to make a couple of calls to transmission shops to see if they have a thicker spacer I could have or buy. ordered a input shaft seal might as well change it while I have it all apart
You really can't tell from the pictures but all the valves were hit and are slightly bent some even got hit a second time, pistons don't look to bad but the valves will need replacing I have the spare engine I might just swap heads plan to do that this weekend
#168
that sucks dude...I can't even imagine how lucky I was to have not bent any valves when my timing belt failed...
about the diff, this has got me very intrigued, as with my Quaife, and RalliartN's Quaife, both times the original spacer ended up within spec...when you measure the solder, what measurement were you getting?
#169
I finally got around to ripping the head off of the white car. Cylinder 1 and 4 were untouched in mine, Cylinder 2 and 3 however have impact marks from both intake and exhaust valves. Dunno how that happened...
Good luck with the head swap if you havent already done it. Im going to put mine together this week and go ahead with all the mods. Ive hit a wall with my turbo configuration though. Cant wait to see more of your build once you get past this.
#170
MD727661 SPACER,M/T DIFF 1 $0.00 $6.48 $6.48
MD720943 SPACER,M/T DIFF 1 $0.00 $6.82 $6.82
MD710457 SPACER,M/T DIFF 1 $0.00 $7.59 $7.59
MD710454 SPACER,M/T DIFF 1 $0.00 $7.59 $7.59
MD720940 SPACER,M/T DIFF 1 $0.00 $4.08 $4.08
The above is only a sample.
Sorry, I didn't read this post before.
#171
#174
Its going real slow for me because there's just so much going on, work around the house, taking care of the pool stuff, maintaining the truck I just bought and the wife's car, and of course family time hahaha there's not enough time in the day
#179
Thanks! I sent the wife to pick one up from the local stealership 5 bucks more than I would have to pay online but this way I can get it before the weekend, I ordered one online last week and it wasn't the right one and its so cheap its not worth sending back hahaha
