NorthStar Creations Engine dampener
If the stiffer motor mounts don't solve my wheel hop problems, I'll look into getting this one. It seems the other one is a science fair version of this one anyways
I was really looking forward to an oil dampened version too!
so, this damper doesnt quite fit, I think it's a manufacturing error but here are some pics, you tell me if I'm doing something I dont see. I know I can make it work but I need a longer bolt, and a longer center piece....
I had the same problem with mine, I made it fit somehow, placing the front part first, then the back. That and rocking the engine a bit until I had enough clearance. It made the car perfect for AutoX, the engine still moves, but not as much, only 33 percent of what it used to move. To me its a good mod. Im even replacing the bushings with harder custom ones for racing days and weekends
I attached a pic of the probelm, take off the center linkage and disasemble it and make the end L joint face the other way and the hole will lign up. i had the same problem and it was fixed by doing that.
nah, you guys are wrong, if you turn the L-Joint then it's a half inch to far forward. I cut a half inch out of the center black tube piece, then turned the L-Joint and it lined up. But looking at the pictures, I notice mine is on much more of an angle. from the strut brace to the engine brace, the bolt is not straight.
So I got it installed and it does work really good, tightens it up. But I still think they sent me the wrong piece, but it seems to work fine, I've send the company an email with pictures too, so i'll see what they say.
