Stock AFR target and Timing Tables
I spent some time last night and imported some of the reverse engineered maps into EcuFlash so I could show some pretty tables for everyone. Here is the stock AFR target table and the timing table. Given the compression ratio, bore size and all that you can see the stock timing is pretty conservative in some places.
Unfortunately as I've always said this car has open loop/closed loop problems and it doesn't switch into open loop until above 80% throttle or a load value of 128 between 2000 and 4200 RPM. So above that it runs nice and rich but below that it's still in closed loop and the entire closed loop target table is 14.7 - obviously with no wideband from the factory!
The timing is nice and conservative but I believe they've given it a lot of advance at 4500 to get a smooth mivec switchover. When I was testing my piggyback for this car I ran into a problem with this. Since 26 degrees of advance is almost MBT you can't easily add timing unless you do it selectively. The ECU allows it to retard as low as 21 but that knock value becomes memorized and will then be applied to the entire table. In my case I had an NA ralliart, added 3-4 degrees on the map and it made decent power but after a week it had lost most of the gains. Turns out 26+3 is 29 degrees and that's too much it would ping and pull 3 degrees. Net gain? Nothing! All for one bump on the map!
I'm still working on the mivec routines but honestly, mitsubishi picked a good place for the mivec switchover and I doubt it will be something people want adjusted unless they're running big cams.
I've also started working on a reflash device so you can order this box and flash/tune your own vehicle. Can't promise a date for it yet but it's in the works.
It's going quite well actually... I've been playing around with something special to allow realtime tuning. At this point it's still a concept but I believe I can make it work. Unlike others who have tried it you won't be limited to a fixed number of updates before needing to flash your changes in. Currently I am in the process of removing all the components from the board and mapping out where all the traces go.
Some of those limits are related tot he capacity of the sensors on the board. That does not exclude us from putting a sensor with a larger capacity and adjusting the tables in the ECU. Also, please note this work so far is for the NA ralliart with the 4G69
Absolutely. The open loop/closed loop criteria appear to be based on coolant temp and throttle position. I thought they took the MAP sensor or MAF reading into account but they don't seem to. I have done a reflash on our test vehicle that keeps it in open loop all the time so it's definitely possible.
