04-06 Ralliart Engine/Drivetrain (no forced induction)
Part interchange help
Old Jan 4, 2010 | 01:29 PM
ralliartucar's Avatar
Ok we just got a ralliart that is wrecked that we are going to use as a circle track car. I am having a hard time finding parts cars. I need the part that the throttle cable hooks to mine is missing, but I found one that has the aluminum piece broken but the sensor is intacked. The question is what other cars and years have this part? Oh and my car is a 2004 Ralliart 2.4 Mivec.
Old Jan 4, 2010 | 08:01 PM
lsalex's Avatar
i think that 2008 eclipse has the same wires..
or any ralliart
its expensive
Old Jan 4, 2010 | 08:15 PM
I know where there are about six of those in a junkyard, but couldn't find the part on them. Maybe it is in a different place, but I couldn't even find the throttle cable coming out of the fire wall.
Old Jan 5, 2010 | 10:25 AM
GearDownSon's Avatar
If im not mistaken you can interchange that part with an Outlander that has the same motor.
Old Jan 5, 2010 | 12:25 PM
RalliDew's Avatar
you in the pro 4 class? thought it was 2.0L max lol and i wouldnt use the RA engine for that see if you can get an old 4g63 i promis it will do better with cost and function...
if you have the servo for it and the plug you can make a cable np
get us some pics of what you got and im sure we can help better.
Old Jan 6, 2010 | 01:22 PM
I cant figure out how to get the picture on here, but the place where you hook the throttle cable and the shaft have been ripped out
Old Jan 7, 2010 | 12:10 PM
Ok, I found out the part number at Mitsu and then on here (mr578861 pedal position sensor). Now where do I get one without breaking the bank? I can't seem to find any of these cars in the junkyards and racing season is around the corner. Any help is appreciated.
Old Jan 7, 2010 | 12:23 PM
The class i'm running does not have any restrictions on size. We've ran the early 90's 2.0's alot and still have several and plan to run them. But wanting to try something different. The dohc cars have to weigh 2600 pds, but no minimum on the sohc cars. We are adding 200-300 pds to our 2.0's so I think the weight advantage would be worth the change.
Old Jan 7, 2010 | 01:08 PM
Thomar's Avatar
the other way to attach images to a post is via the 'Insert Image' button.
Old Jan 8, 2010 | 05:58 AM
Ok, thanks for the help but I think we've got the part. We messaged everyone selling parts on the internet and a guy in Conneticut says he's got one for forty bucks. He's seen pics so hopefully it works.
Old Jan 19, 2010 | 04:33 PM
OK, new problem. Got another pedal position sensor, but after a few minutes of running fine it cuts back to 2200 rpm's max. This set up does not seem very good for circle track racing. Is there any other throttle body that will work to bypass this and hook a throttle cable straight to the tb itself.
Old Jan 19, 2010 | 05:17 PM
RalliDew's Avatar
changing to the mega squirt engine management to be able to switch to the cable and then you can go to a TB that has a cable set up and weld it to the manifold like another person did on here. but still alot of work youll keep running into problems cause the ECU is very stuborn
Old Oct 25, 2010 | 01:40 PM
owexonline's Avatar
not sure ...
not sure your interested , I got the same sensor , the aluminium spring part is intact, the electronic part is broked in mine . I can give you my part , or you can give me your part preferably the second choice for me )
let me know
Old Oct 25, 2010 | 02:21 PM
Bought a new one $260
Old Nov 2, 2010 | 05:25 AM
owexonline's Avatar
ralliartucar
ralliartucar <---
Do you still have the old broken part ? I only need the electronic part of this. If you have it , will you sent it to me , from 2 broken parts I might get a 1 working part. Thank you
