Stayer. Pistons.
Stayer. Pistons.
Hi friends!
Continue your project. I wrote earlier that for the construction of necessary engineering approach. That is, first done structural calculations. After that begins the process of compiling details. In this topic I want to talk about the pistons.
To obtain a power of about 300 HP (N/A) for the 4G69, I need to get a CR 11.8 : 1. This cannot be done with stock pistons. Therefore, I need custom pistons.
I considered various options. For example, well-known companies (Wiseco, CP, Cosworth, etc.) do the pistons. The problem is that all these pistons are forged. Don't think forged pistons are cool. Doubt?
In this case, ask yourself the question, why not install forged pistons from the factory? Why the best and the most powerful cars from the factory, have the cast pistons?
Yes, forged pistons are more durable. But they have a significant disadvantage. This thermal expansion.
Cast pistons have the clearance 0.02-0.04 mm.
Forged pistons have the clearance 0.06-0.10 mm.
A lot or a little? Because of this, forged pistons have a higher noise level. And most importantly, they do not go more than 30k miles. Further, the oil flow rate becomes simply monstrous. Drops the compression in the cylinders. There is a sharp engine wear.
While cast pistons will run 200k miles (or more)
Also, if you make cast pistons for modern technologies, the strength can be increased significantly. In this topic, I want to tell you how to make pistons.
Next, we obtain a drawing of what we need to.
I have done porting the cylinder head. I have big valves on the inlet and outlet. Therefore, the undercut valves are oversized.
When all drawings are ready, we can start production. I mean, in Russia, it is possible to make a detail of any complexity. Originally done casting in a metal mold.
Next you need to obtain high strength alloy. The pistons are hardened at a temperature of 520 ° C for 8 hours.
Further, the stage of aging. 14 hours at a temperature of 190* C.
The alloy is gaining a very high strength and hardness. The stock pistons do not have such strength.
Why is it done?
The factory, the stock pistons have very low resistance to detonation.
The stock piston will break the barriers between the rings. This is not my photo, I brought them for example.
Why is it done?
After the pistons acquired a high strength, you can start machining.
This is done on precision machines.
Further, it is necessary to apply coatings. On the lateral surface of the piston to apply a Teflon coating black. This really reduces the resistance of the piston friction.
On the upper surface of the piston is applied with a ceramic coating zirconium oxide. In these pictures the top coating is not done yet. It will be up to the end of the week. After I show you the final version.
Sebasthian pena (Feb 19, 2020)
stayer
35
Aug 14, 2017 12:37 PM
stayer
20
Jun 29, 2016 01:05 PM
