04-06 Ralliart Engine/Drivetrain (no forced induction)
Intake Manifold Porting
Old Jun 21, 2018, 07:59 PM
Izerous's Avatar
Been a long time since I have been around here. Actually drive an Outlander but the few things I have done were based on information from this RA section. Anyways quite a long time ago I did the Eclipse GT TB swap but I never did anything to the intake manifold, and honestly with the RRM UDP having been installed quite a time prior to the TB swap I really didn't notice it. Recently I decided to pick up a spare intake manifold and put my dremel to work and ported this spare intake manifold. Re-reading the TB swap thread there are comments about the IM being 62mm opening but it measured to 60mm for me.
Anyways I cut it open so the initial section in the flange is now a full 65mm and the smallest cross section in the short distance to the main chamber I opened to 63mm. Now I'd like to open it all the way to 65mm in this short section but I have concerns about how much material is safe to remove and how this the walls need to be in this section before it could potentially become an issue.
Old Jun 21, 2018, 08:26 PM
Izerous's Avatar
First practiced polishing on a spare 4G69 TB.
Before starting any work on the IM
Current state photo 1
current state photo 2
This is the area i'm concerned about removing too much material from.
CT9A PR
Oct 29, 2015 05:14 AM
blackonblackevo
May 12, 2007 07:35 AM
bluebanana23
Nov 16, 2004 01:52 PM
firechicken
Lancer Engine Tech
25
Apr 29, 2004 02:51 PM
Quick Reply: Intake Manifold Porting
