Replacing valves without machine shop?
So unfortunately had my timing belt go and bent 2 of my intake valves... Wanted to see if it was possible to install two brand new valves and avoid having machine work done?
Basically would there be any additional steps minus lapping the valves that would require specialized tools/machining??
Thanks in advance!
Thanks in advance!
If you're able to take it apart down to where you just need to lap the valves, I would say you *should* be good. I lapped a couple of my own valves and she's still running strong. I'm no gear head by any means though, just one of those 'figure it out as you go' type of guys. When I did my research, that's all that was needed to be done in terms of replacing the valves.
I went ahead and ordered the valves and plan on lapping them this weekend... I’ll update the thread with results. Thank you for the reply!
Doing what this guy did in the below linked video saved me.,.. My car is up and running with no SES lights or hiccups.
You can do leak test after installing the valves in the head. Flip the head over and fill the dome with some water, with the valves closed. See if the water stays and doesn't leak past the valve to head seal.
