-   04-06 Ralliart Engine/Drivetrain (https://www.evolutionm.net/forums/04-06-ralliart-engine-drivetrain-94/)
-   -   Aem Pulley's (https://www.evolutionm.net/forums/04-06-ralliart-engine-drivetrain/152167-aem-pulleys.html)
reimundo Aug 4, 2005 06:37 PM
Aem Pulley's
I bought the aem tru-power underdrive pulley from a 00-04 eclipse which has the 2.4L 4g64 motor. some one told me that they would fit the ralliart. so i'm going to try to put it on saturday. BLKRalliart04 is going to post some picture of the pulleys , so i can know which one is the water pump pulley and how the belt goes. if this does or does not work i'll post up to let you guys know .
BLKRalliArt04 Aug 4, 2005 06:49 PM
1 Attachment(s)
This is the only other pulley i could find in my manual. The other is in the first thread that joe's_evo8 made.
reimundo Aug 4, 2005 06:52 PM
the manual doesn't show all the pulley's at one time?
BLKRalliArt04 Aug 4, 2005 06:55 PM
No it doesnt.
Myszkewicz Aug 4, 2005 10:56 PM
I couldn't find anything, either. There IS a belt routing diagram under your hood, though.
403RA Aug 5, 2005 08:55 AM
There are two other pulleys. Check out the electical section of the manual for the alternator pulley. Also look at the powersteering section for the PS pump pulley.
blk-majik Aug 5, 2005 09:37 AM
tip with the manual: install google desktop (http://desktop.google.com/)
it will let you search local files on ur PC, including the ralliart manaul =) very useful. just serach for 'pulley' and it will bring up all manual pages referring to any pullys
ProjectR#69 Aug 5, 2005 10:15 AM
What color did you get?? How much?? What pulleys get replaced with this kit??
reimundo Aug 5, 2005 10:31 AM
they are blue and the pulleys that get replaced are the altornator and the water pump. joe's under-drive crank pulley is coming next week, and i'm sure this will make a good combo! if it works.
lucas569 Aug 5, 2005 11:02 AM
if they do fit do the joes after to see if you get a power increase....
ProjectR#69 Aug 5, 2005 12:21 PM
I am curious to see what kind of gains you will get from this mod
LatinRA Aug 5, 2005 02:37 PM
im positive this will work for you on the basis that those engines share the same pump and alt so i really hope this works for you..
ProjectR#69 Aug 5, 2005 03:13 PM
how much did you get them for??
reimundo Aug 5, 2005 04:52 PM
$100 for the AEM. $95 for the crank that joe made. i'm putting on the aem first and when the crank comes in i'll put that one to see if i made more power.
reimundo Aug 5, 2005 04:55 PM
do you guys want pictures ?
