02 sensors, CEL's and headers
so i'm running a rrm header, downpipe with a high flow cat and custom exhaust.
i'm still triggering a CEL even with the RRM CEL eliminator i noticed when i was doing the install the tip of the 02 sensor was pretty black, so is the sensor just dirty and needs to be cleaned or is it blown? thoughts? |
If your o2 sensor was on it's way out you would have been triggering a CEL even before your install. You reset your ecu after the intstll?
What code is it throwing? The header throwing a CEL isn't exactly a new problem. Sometimes I just get tired of fighting them and disable it :P
-Michael |
i installed 2 weeks ago rrm headers+downpipe+h.f cat and i already had a magnaflow muffler on. My CEL light keep coming on and off, it depend how it feels, loll. Beside getting the CEL eliminator, is there anything else i could do to not have the CEL?
Thanks! |
I've got the OBX header/dp and i've tried everything to get rid of that p0420 code. Tried different combinations of the same fowler rrm uses for there fix, a highflow cat, and a combination of the two. Nothing works for me :(
Buy the elminator from Weapon R it works I've never had a P420 code since I put it on.
| All times are GMT -7. The time now is 08:25 PM. |
