S&S Sub x 2?
Old Nov 28, 2004 | 05:06 PM
blk-majik's Avatar
S&S Sub x 2?
A friend offered to give me her S&S Sub after she redid the sound system. I already have the S&S system, but I was thinking of putting it on the other side. I know the bolts are in the wronge place, but I can take off the mountings and just put them in the right place on the plastic casing (or put new ones on). anyone try this yet? will the amp be able to power them both? if it works, I need PDX to make me a new strut bar to fit on both sides
Old Nov 28, 2004 | 05:13 PM
otter's Avatar
EvoM Administrator
I doubt you could do it. The stock amp won't be able to power two subs (wrong impedence plus not enough juice). I don't know what the impedence is on the S&S sub, but I doubt it'd run off an aftermarket amp without blowing.
Old Nov 28, 2004 | 05:16 PM
blk-majik's Avatar
i planned on replacing the HU. a new amp wouldnt hutr, either. but yea, i think I'll have to get another one if i do it. Ill check to see if I can get it to fit first
Old Nov 28, 2004 | 05:22 PM
lrh35's Avatar
If she is redoing everything then get ther old amp too.
Old Nov 28, 2004 | 09:08 PM
Deltarider99's Avatar
Chucko66 tried running his S&S sub with an aftermarket amp, and ended up blowing it. So don't try it!!
Old Nov 29, 2004 | 10:15 AM
lrh35's Avatar
If I remember right he ran his new amp off of his old one in a series and that is why that happend. He didn't know how to hook it up right.
Old Nov 29, 2004 | 11:13 AM
otter's Avatar
EvoM Administrator
Anybody know the impedence and power rating of the stock subwoofer? That would be a big help in figuring out this problem.
Old Nov 29, 2004 | 11:39 AM
blk-majik's Avatar
just take an ohm meter to it. i'll do it when i get that far =)
Old Nov 29, 2004 | 11:44 AM
EVOL 8's Avatar
2 stock amps and two stock subs should not be a problem if run correctly.
Old Nov 29, 2004 | 10:17 PM
MitsuRalliArt's Avatar
My guestimation on the stock sub is 2 ohms and 200 peak watts.
Old Nov 29, 2004 | 11:23 PM
otter's Avatar
EvoM Administrator
