"Tight as a drum" construction?
Old Jan 9, 2005 | 01:01 AM
bigdoggy_dog's Avatar
While we are on the squeaking issue. What would cause my brakes to squeal or grind when I back out of my driveway? My driveway has a serious decline when you are coming out.
Old Jan 9, 2005 | 01:28 AM
blk-majik's Avatar
rotor rust. rotors are not finished at all and will oxodize over night. take a look at them in the morning. they will have a yellow film over them. wana see a good example? check out my registry and look at the pic of the calipers. the rotors are all orange in that pic =) it wears off after you hit the brakes once and run them through the pads. that would cause the grind.
but they shoulndt squeek until they are getting low. the squeeking of low break pads is a safety feature to let u know they need replaced....but that would happen every time u hit the breaks. not when they are just cold....
Old Jan 9, 2005 | 02:02 AM
reimundo's Avatar
my car sqeaks too , is it the shocks?
Old Jan 9, 2005 | 02:56 PM
turbonutter's Avatar
I've had the car for about 2.5 months now, no problems yet. Most "problem" cars exhibit their problems very early on, so it's a good sign thus far.
Old Jan 9, 2005 | 10:59 PM
Squeaking was a bad choice of words. I know what it sounds like when you need new breaks. Plus, like you said, it would be constant. This is just an occasional grind I guess.
Old Jan 11, 2005 | 03:31 PM
shiroboi's Avatar
Bigdoggy, 2 things. If it rains, mitsu rotors do rust up quick. That creates the grinding noise and as someone already stated, that will wear off after you apply the breaks once. If it squeaks when you are in reverse, then that has to do with backing up with the ABS brakes. Or at least thats what I've been told. It was discussed awhile back.
Old Jan 11, 2005 | 07:09 PM
ralliart86's Avatar
i get a few sounds in mine... a break squeak when backing up when its cold out and the car is cold... goes away after the first time i push brake... the suspension makes a few creaks when its really cold... but i think its just settling back from being cold
Old Jan 11, 2005 | 10:14 PM
pocoRA's Avatar
I'm getting a knocking noise when turning the steering wheel, I think it's a CV joint, I was supposed to bring it in this week, but looks like I'm gonna be out of town.
Old Jan 11, 2005 | 10:17 PM
MitsuRalliArt's Avatar
I had wierd squeaking noises in my old Honda. I then found out that the dumbasses at the factory accidentally installed 2 mice instead of dual hamsters.
Old Jan 11, 2005 | 11:52 PM
lol
Old Jan 12, 2005 | 04:59 PM
captain150's Avatar
I get the usual break groan/howl in reverse. Get some suspension creaks. I get the odd knock when I turn the wheel. But it has been -20 to -30 out lately. Every car makes odd noises. Our Volvo makes crunching noises from the front end. Our trailblazer sounds like a semi.
Does anyone else notice, when it is REALLY cold (like my tempuratures) the brakes are REALLY touchy?
BTW the brake howl is caused by rust on the rotors, not the ABS.
Old Jan 12, 2005 | 05:51 PM
cycovizion's Avatar
Thumbs up
yea, it's a CV joint if you are hearin the knocking when turning. shouldn't cost too much to fix..
Old Jan 12, 2005 | 09:46 PM
otter's Avatar
EvoM Administrator
Shouldn't cost anything to fix.
Old Jan 14, 2005 | 07:25 PM
captain150's Avatar
That depends. Is it a single knock or a repeating knock? If it's a single knock, that's a dry/loose tie rod, ball joint or strut mount. And it is fairly rare to blow a CV joint unless the boot is torn. Of course that's unless you race a lot or constantly burn out will in full lock left or right.
Old Jan 14, 2005 | 08:37 PM
pocoRA's Avatar
It's a repeating knock, does it when I'm rotating the steering wheel at low speeds.
