Front lip Damage NEED HELP!!!!
Ok today I was driving and I hit a snowbank. There is no damage to the bummer its just that when I backed out I tore off the right side lip a bit. One of the clips is still ok but 2 broke off. It looks like it will be easy to fix but I need to know what I should use to glue the clips back on to the lip. What would work best with the material the lip is made of??(I dont know what it is probably polyurathane) Crazy Glue , Epoxy . . . ANY HELP WOULD BE AWSOME!!! THANX
i just taped mines up with electrical tape from when my friend tore my lip off driving my car. Nothing big just a strip every foot until you reach the part where it's connected still. Just retape everytime you wash your car and you're all set. Looks really bad, but it's an easy fix, especially if you suck at gluing things like i do.
i say put a screw in it like you would a regular lip, right at the corner in front of the right front tire. nobody will look there. i wouldn't epoxy your lip to the front bumper. but each his own. good luck.
