First Oil Change
Old Aug 14, 2005 | 05:32 PM
ralliart_dreams's Avatar
Cool First Oil Change
Just changed my oil for the first time yesterday (at exactly 3000 miles ). I put in Mobil 1 5-W30 Full synthetic. In the professional opinions of the posters on this board how long can I go before changing the oil again. Also, the filter I picked up at Advance Auto (Fram TG7317, i think) had a differant out diameter than the on from the factory. I havent noticed any leaks yet but is this normal?
P.S.: If you go to Advance to pick up any parts, they don't register the Ralliart (they only have the 2.0l). To get proper parts for your engine they have to use the Sportback, just an FYI.
Old Aug 14, 2005 | 08:08 PM
CF-Ninja's Avatar
from what i've heard there are two different oil filters that both fit our car.... Doesnt make much sence but yah... You should be all right if its not leaking
Old Aug 14, 2005 | 08:34 PM
bigdoggy_dog's Avatar
It's just the outer rim that is a different. The seal and threads line up and that is what counts. What's freaky to me is how tiny the filter is.
With synthetic you should be able to crank out an extra couple thousand miles.
Old Aug 14, 2005 | 10:59 PM
Myszkewicz's Avatar
I laughed when I first saw the stock filter that came on my car. Then I got mad at it, because it was on WAY tight, and my filter wrenches were too big. I ended up using a chain wrench to get the original filter off.
I use a bigger filter. When I was using the Mobil1 filters, I got the M1-110. The M1-105 would fit, too, and is larger yet. That's the one I used to put on my GSX.
Now I have a Purolator Pure-One filter on that's about the same size as the M1-105, but a couple bucks cheaper.
The plus to using a slightly larger filter is then you can just dump 5 quarts in, instead of 4.6.
Old Aug 15, 2005 | 07:07 AM
jdizzy's Avatar
Is that the filter that is right by the passenger side wheel well? I have free maintenance so I haven't changed it yet but holy crap that is easy to get to... on my ES you had to fish your hand up around the back of the engine...
Old Aug 15, 2005 | 08:16 PM
Yes that's it. I almost didn't think it was it at first because it was so tiny.
Old Aug 16, 2005 | 04:18 PM
I know what you mean. The filter and the drain plug where on painfully tight. The plug was on so tight I had to tap the socket wrench handle with a hammer to get it to break. Then the filter was bigger than the filter sockets I had so I had to dig out the old strap wrench. After straining for several minutes and burning my wrist on my exhaust it finally came off. The new filter is on with a more proper torque.
Old Aug 16, 2005 | 04:26 PM
IXMR's Avatar
well i have 25,000 miles on my gm 4.3 262cu. in. since my last oil change (im lazy,real real lazy) and i run syn. oil (never do this i am a trained professional) but the viscosity breaks down faster in a turbo engine, you may be able to 2-3k over 3k but its not recomended just do it every 3k your, engine will last longer
Old Aug 16, 2005 | 04:58 PM
Myszkewicz's Avatar
I don't recall having any difficulty with the drain plug, but I replaced it with a drain valve during the first oil change anyway. It's nice to change oil without needing tools.
Old Aug 16, 2005 | 06:24 PM
vonzipper's Avatar
drain valve where can i get one of those and which one do i use, how much do they run. i have heard of them and i wanted one
Old Aug 16, 2005 | 07:19 PM
CF-Ninja's Avatar
What are you trained professional in? Being to fat to get under your pick-up truck? i wasnt aware that oil could last 25k....
Old Aug 16, 2005 | 07:24 PM
Myszkewicz's Avatar
I got mine from Fumoto valve. They have a part # lookup on their site.
IIRC, the one I got cost about $25.
Old Aug 16, 2005 | 07:27 PM
Ralliartist's Avatar
Burninated!
Old Aug 16, 2005 | 07:31 PM
Myszkewicz's Avatar
Originally Posted by Ralliartist
Burninated!
that reminds me, I haven't been to that site in a while...
Old Aug 16, 2005 | 07:35 PM
CF-Ninja's Avatar
have you had any drips with that valve? i dont know if i'd trust a vavle or not...
