Leaky Washer Nozzles?
Old Jun 19, 2007 | 12:53 PM
Eclipse2Lancer's Avatar
Did a search and came up with nuthin.
Does anyone else have the problem of leaky windshield washer nozzles? I have ignored this problem for awhile.....and it now has reached the point of minor annoyance to me (especially just after I clean the car).
The only thing I found is that a couple of guys have Galant nozzles (why is that?)...nothing else. Anyone else have leaky nozzles?
Old Jun 19, 2007 | 01:05 PM
Lancer7's Avatar
Mine leaks every once in a great while. Just the passenger one. But it only leaks after I use it which isn't that often so I didn't worry about it.
Old Jun 19, 2007 | 01:47 PM
ralliartpr's Avatar
The Galant nozzles sprays like a fan , it cover all the windshield.
Old Jun 19, 2007 | 02:41 PM
otter's Avatar
EvoM Administrator
Galant nozzles FTW!! One of the first mods I did They do a better job of covering the window when they spray, plus, they're all plastic, so they won't rust like the stock ones do (where the spray comes out).
Old Jun 19, 2007 | 05:20 PM
Cj98's Avatar
AH! I may go pull some off at a junk yard I know of! Thanks for the reminder
But yea mine used to do the same thing now it stopped
Old Jun 19, 2007 | 06:06 PM
$MIVEC$'s Avatar
yeah mine leak and its so annoying...stains all over the hood ... i thought i was overfilling the washer system but it still happens....i fill it up less and it happens less often thou( maybe its mental)
Old Jun 19, 2007 | 09:31 PM
bruce988jl's Avatar
I rock galant washer nozzles.. Legit they cost at most 10$ for 2004 versions. Go for it, just order it from the dealership, they're so inexpensive and well worth it.
Also i don't have any leak problems or any problems with the sprayers spraying on teh highway, it only pushes the spray lower on the windsheild but still covers at least 200% more area than the stock ones do.
Old Sep 21, 2007 | 10:54 AM
JTB's Avatar
JTB
I had this problem. Under braking the fluid would just gush out and pool in the hood vent. It would also leave nice looking blue stains when it dried.
The solution is easy and cheap. There is a check valve designed to keep this from happening just before the sprayer. I would recommend buying 2
It costs about $1.85. described as "Joint, Windshield Washer" part # MR388278
Old Sep 21, 2007 | 11:56 AM
chengstar's Avatar
yep....thats why i dont use it anymore...the runoff on the hood is a pet-peeve when i clean my car....
open sunroof and waterbottle with holes for the win......on a dead stop of course.....made the mistake a few times doing it while driving....haha...
Old Nov 17, 2007 | 07:38 AM
TouringBubble's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=286464
If you look on page 3, I mention that it could be a siphon issue. I haven't tested it yet. I'll try the windshield washer "joint" thing too. I can't remember if I removed anything like that when I installed my Galant nozzles.
Old Nov 17, 2007 | 07:44 AM
AWDaddict's Avatar
Mine just get stuck from time to time when I need it. *shrugs*
