racing harness
Old Sep 4, 2007 | 09:21 PM
duderr_666's Avatar
racing harness
i was just wondering are racing harnesses illegal? i live in canada and am wondering if it is illegal here
Old Sep 5, 2007 | 05:14 AM
Realistic's Avatar
yes
Old Sep 5, 2007 | 06:28 AM
blaze_125's Avatar
Your answer in somewhere in there:
The quotes below were taken from 2 different message boards, but the person answering the question stays the same. Emre Kaylap, driving instructor.
Originally Posted by JohnathanKong
I just installed racing seats with 4 point seat harnesses, and now people are telling me that it is illegal. Is this true?
Originally Posted by LanEvo
Yes. 4-point harnesses are totally illegal both on the street AND on the track. Nothing less than 5-point is allowed on the track (and only with adequate roll protection and proper mounting).
One of my friends is telling me that I could get pulled over for using a 4 point seat harness. He said it's because cops are only trained to cut people out of 3 points in emergencies.
The reason why they are illegal is because they are deadly. It's that simple.
Without the 5th belt (a.k.a., anti-sub strap) you will submarine under the seat in any sort of high-speed impact. Believe it or not, your stock 3-point belts are designed to protect you from submarining. This is why "tuner belts" are outlawed by the US DOT, the German TUV, Transport Canada, and every race sanctioning body in the world (including the SCCA and ASN/FIA). Schroth did manage to put together a 2" 4-point tuner belt system that got DOT approval. It relies on a break-away strap. Personally, I wouldn't go near it.
Emre
LanEvo and Kayaalp are the same person... but his name changes from board to board.
Originally Posted by Kayaalp
There's more to it than that. Generally speaking, 4-point harnesses can be more dangerous than your stock inertia reel 3-pointer in high-speed frontal impacts as there is no anti-sub strap. We're talking major intra-abdominal blunt trauma (ruptured spleen, liver lacerations, ruptured intraabdominal aorta, etc.) ... this is serious stuff. I'd rather have a bad craniofacial injury than that...you generally don't die from craniofacial injuries. I've spent enough time in trauma centers to stay away from 4-point systems in a road car.
Plus, if you have a harness bar in the car without proper roll protection, you've pretty much signed your own death certificate if you ever actually roll the car. With a stock 3-point belt, you have a chance of surviving: you can get pushed to the midline of the car by the roof as it comes down and be ok. Also, the seatbacks on ALL cars are designed to collapse. If the roof comes down, your seatback can collapse and flatten out. (I know at least 2 people who survived roll-overs this way). This can't happen if there's a steel bar behind you! You'll be broken in half as the roof folds you over it. Not pretty.
Also, if you go backwards into a wall at high speeds the seatback can sometimes collapse...or the seat mounting bolts can snap. This is how the ex-president of the COMSCC died. He spun his Corvette, went backwards into the wall and the mounting bolts on his seat broke. He flew backwards into his harness bar and it broke his neck.
Bottom line: if you are using a stock seat and have no roll protection...use the stock inertia reel belt. If you feel you need more protection, then use a proper 5-point belt with adequate roll protection (4-point bar at minimum). You can use your stock seat if you cut a slot for the anti-sub strap and use a seat-back brace like those sold through i/o motorsport to protect you if the seatback collapses.
Be safe.
Emre
If I remember correctly, Canadian laws require you to use OEM seatbelt when driving on the public roads. Given you had a proper 5 point harness, you could ride with both setup. Latch your harness, and buckle your oem seatbelt.
Old Sep 5, 2007 | 01:04 PM
heartagram88's Avatar
ok well that was very helpful but what about aftermarket seats...are they illegal in the states...i mean i know the evo comes with recaro seats and i know those are legal or they wouldnt have them in i, but im talkin about seats like the sparco EVO2s or the sparco Fighters (might i add are the seats i want to get) are seats like that illegal...
Old Sep 5, 2007 | 01:45 PM
theblue's Avatar
any harness on the street is a stupid idea.. since you can't move your shoulders you can't move around to see your blind spots so you're asking for trouble.
skidmarq
Northwest Region
20
Dec 6, 2011 08:01 PM
RA032924
Canadian Forum
18
Mar 31, 2010 05:51 PM
Pivotto
38
Sep 22, 2009 08:57 AM
Billy
Dec 21, 2001 12:04 PM
