Motor mounts and where to find them?
Old Dec 24, 2008 | 12:41 PM
NathanV's Avatar
The motor mounts in my car are bad! The driver side motor mount is damn near gone and needs tending. Where can I find either an aftermarket or OEM part. I already ordered the RRM motor mounts but I don't think they will fit the driver side mount... Or will they?
Any help on this one is most appreciative!
Old Dec 24, 2008 | 01:47 PM
otter's Avatar
EvoM Administrator
RRM's mounts replace the front and rear mounts. If you want to replace the trans mount, your only option is OEM, since I'm pretty sure that the Evo's trans mounts won't work, so there's no aftermarket options.
Old Dec 24, 2008 | 06:57 PM
Ralliart_on_LSD's Avatar
junk yard FTW... If they don't have a match for you, a good junk yard should be able to look up in there computer and find out which local junk yard DOES have the part, and can tell you where, or at least have it mailed to you soon. This happened to me with a transmission, and an axle on seperate occasions.
Old Dec 24, 2008 | 11:03 PM
NathanV's Avatar
so the mount i'm looking for (on side of the intake and battery) is the tranny mount?
Old Dec 25, 2008 | 09:06 AM
EricJ@AMS's Avatar
NathanV, I am almost positive that the poly insert that we make for the Evo will press into and replace the rubber on your Ralliart Trans mount. The two rubber side spacer pieces share the same part number as Evo, so I would think the actual insert is the same.
Old Dec 25, 2008 | 01:43 PM
NathanV's Avatar
I checked out your website and what you're talking about the the poly trans mount rubber inserts? Also, is this the trans mount that I'm needing or...? Thanks for the help so far guys. I appreciate it ^__-
Old Dec 28, 2008 | 04:56 PM
edbighead's Avatar
wow that would rock as at only 55000 the motormounts are starting to go bad and if i can replace all of them with aftermarket that would be cool.
Old Dec 28, 2008 | 05:27 PM
bruce988jl's Avatar
Nathan, its hard for us to understand which motormount you're specifically talking about without a photo. Take a quick photo of the engine bay so we can figure out which one you're talking about. I have replaced both my front and rear as those tend to go, I've never heard of replacing the tranny mount on any RA's. Or at least no one has posted about it that I know of.
therunningskier
Apr 14, 2020 09:50 AM
TheLancerLife
Jul 10, 2017 02:06 PM
Emmy
Nov 3, 2016 02:51 PM
johnnnyjeans
Jan 1, 2013 10:39 PM
Apex Racer
Jun 20, 2007 10:48 AM
