The infamous P0171 HELP !
Old Sep 27, 2010 | 09:40 AM
AdamRA's Avatar
Originally Posted by Ralliartize It
Have you tried replacing the coil packs?
No that would have been a very obvious problem. Most likely it would of thrown a mis fire code as well.
The car is running 100 times better right now.
New clutch/flywheel scheduled to arrive this week then off to get the transmission rebuilt and the LSD put in.
Old Sep 27, 2010 | 09:56 AM
Ralliartize It's Avatar
You'd be surprised at what failing ignition coils can cause besides misfires.
My next guess is either your TPS, clogged fuel filter/dying fuel pump or dying injector(s). I have a subscrition to ALl Data if you need me to look up any test methods for you.
Old Sep 27, 2010 | 10:25 AM
AdamRA's Avatar
The exhaust leak was causing the problem. Now that the main big leak is fixed the AFR is back to 14.7 and it's close to running 100% I still have some boost issues but I know it's because the wastegate flanges are leaking. Fun times.
I'll need to make my own gaskets as it looks like the manifold to wastegate connection is on an angle.
Old Sep 27, 2010 | 10:30 AM
Get some Mr. Gasket material and get to work! Always happy when you beat your demons ain't it. I've been fighting a random no start for a year now.
Old Sep 27, 2010 | 11:09 AM
lanzerralliart's Avatar
EvoM Super Moderator
What LSD is it? Rrm?
Old Sep 27, 2010 | 11:36 AM
AdamRA's Avatar
Yes the RRM LSD.
Works Stage 2 clutch and flywheel as well.
I don't feel half as bad as ROLSD. I've only spent a 1/4 of what he has.
Old Sep 27, 2010 | 11:49 AM
Ralliart_on_LSD's Avatar
I get free money anyway. uncle sam loves me
Old Sep 27, 2010 | 12:49 PM
Man I want that LSD but the coin is to much right now. I'll have some more stuff in the for sale section soon that should help me out a little.
Old Mar 4, 2011 | 07:39 AM
2006_RA's Avatar
TSB 0613009.
Replace injector O rings 1465A188 and injector insulators MD087060. Remember to get 4 of each.
Old Mar 4, 2011 | 09:44 AM
Mark22300's Avatar
Originally Posted by AdamRA
I'm stumped my car has been running some what poorly for a while and only recently I've got this code.
I get horrible gas mileage which is only getting worse it seems. Barely making 300kms a tank even if I baby it.
The car does some funny things when I'm stopped if I rev the motor just a tiny bit the AFR goes to 11.0 then jumps back 15.5 it also doesn't seem to stay as close to 14.7 as it used to I've seen it randomly at idle go way past 16 to -- on the gauge. Not all the time but it seems as though it's a struggle to keep it at 14.7
I'm getting a fuel pressure gauge and a compression tester tomorrow because I can't think of what else I could do, accepting all ideas.
I'm thinking it might be the fuel pump it was used when I got it.
Idle RPM is fine and Vacuum at idle is fine no bounching needles.
So far I've replaced/checked
02 Sensor
MAF
Spark Plugs
Checked for Exhaust Leaks
Checked Injector Resitance
Checked all vacuum lines including brake booster lines and check valve.
Boost Leak tested no leaks
im getting the same thing but im getting 180km to 3/4 of a tank.... if u find the problem out please pm me im stumped to
kaj
May 27, 2015 06:11 PM
Sirlegregs
Oct 11, 2014 02:00 PM
Foggy
Feb 28, 2013 05:36 AM
fastyouth1313
Jan 5, 2013 10:29 AM
IBAUCLAPlaya
Sep 13, 2009 10:05 AM
