Fog lights
Fog lights
This morning we had a lot of fog, so I turned on my fog lights but I didn't see any difference. Is it because I have HID's or because they are week or there is something wrong with them?
Fog lights really only provide a light at a low angle so the light from your headlights which is reflected back by the fog does not blind you, or make it hard to see. So if it was already light out, you wouldn't see too much of a difference
Well typically fog lights are yellow to reduce the amount of light that reflects back. I have yellow bulbs in mine and although they don't shine very far, the local clarity is improved.
What color bulbs do you have?
i have 6000k hids in my headlights. and stock bulbs in my fogs, but yellow laminix over the lense to make the fogs yellow, my headlights are VERY bright and i have no problem at all seeing my yellow fogs they are actually very bright, and i have 8 dollar ****ty bulbs in them
I run the Nokia Hyper Yellow fog lights and they seem to work well in the fog. They are really bright to. The key that I found was to lower your head lights with the switch on the drivers side. This will keep the light from reflecting back at you and blinding you. Not to sure if the RA has this lovely tool or not but if so I recommend lowering your lights while in fog. Hope this helps.
aaron
aaron
