Headlight Adjustment
Old Nov 18, 2012 | 02:56 PM
Phukit's Avatar
Hi,
I have the projector headlights and my HID I just installed is pointed to the ground I would like to raise them up a little bit.
In the pick is the bolt closest to the arrow the adjustment for vertical or horizontal?
Is the other bolt that is up high to adjust the high beams?
Thanks.
Old Nov 18, 2012 | 03:04 PM
CrAnSwIcK's Avatar
the pics to small, i can't really see. on the stock assembly, the adjustment is a 10mm nuts if i remember correctly, very hard to reach with the headlight installed in the car...if that shiny thing near the arrow is a 10mm nut, i believe that is vertical...
Old Nov 18, 2012 | 03:07 PM
Phukit's Avatar
I believe it could be a 10mm nut with a philips head in the middle as well.
I forgot to look to see before I installed them
EDIT: I will probably take some pictures and see what that bolt is and controls will let everyone know what I find out.
Old Nov 18, 2012 | 04:16 PM
Lancerzz's Avatar
On my Depo projectors it's the screw towards the top right in your picture that adjusts it vertically. And the Hi and Low beams adjust together. You can just twist it with your hand and see which way it moves inside the lense. You can adjust it easily even if its installed on the car already.
Old Nov 18, 2012 | 04:58 PM
Phukit's Avatar
I googled the Depo headlights and they are different then the ones I have. But will try it out tho and see what happens.
Thanks
Old Nov 18, 2012 | 05:30 PM
Phukit's Avatar
I found these pics of them.
Looks like the 2 screws do control both hi/low beams.
Thanks.
Attached Thumbnails Headlight Adjustment-02-az-ml03-pbc-r-01.jpg   Headlight Adjustment-lp-mlan03bbr-ks-.jpg
Old Nov 19, 2012 | 06:25 AM
Lancerzz's Avatar
Yeah those look completely different once I see the front of the lights. Let us know which one it is when you find out.
ekinshuya
Dec 19, 2014 04:51 PM
Eltnoon
Sep 23, 2014 06:05 AM
2011gts
Lancer How Tos / Installations
Jan 17, 2014 02:10 AM
RalliArtEvoVIII
Apr 21, 2005 08:27 PM
MidNight_Sky
Lancer Troubleshooting
11
Apr 29, 2003 05:18 PM
