Progress sway bar + perches review/picz
Old Apr 1, 2005, 05:26 PM
reTro's Avatar
I just finished installing the Progress perches + rear anti-sway bar. I didn't know what to expect performance wise, but I was pleasantly surprised! You can feel the stiffness right away and take hard turns with much more confidence! I can't believe how solid the car feels now! I highly recommend this mod.
Overall, the install was easy! It took approximately 1.5 hrs. The instructions say to put the car on stands and take off both wheels... I didn't see the need or advantage to this.
Here is how I did the install:
1. Jack car up and place two (2) 4x4" side by side under each back wheel and lower completely. This seemed to give me the proper height to get under the car and places the suspension in its "normal" stance. If wheels are left hanging, bar is impossible to install.
2. Take off ALL factory hardware with 12mm and 14mm sockets. Therez really no particular order to this, just save all bolts/nuts since anything that bolts back to frame is needed.
3. Bolt perches to frame with factory bolts. These are the only factory bolts you re-use.
4. Bolt sway bar to perches with clamp. Make sure you grease (supplied) the INSIDE of the D-shaped rubber bushing that goes over the bar and in between clamps. Don't tighten completely!!! You'll see why later.
NOTE: be sure sway bar is facing correct way, or you'll have to unbolt everything just to turn it around!!! Ends face front of car, bend goes down!
5. This is the tricky part. Install ends this way (refer to pic): bolt end, washer, rubber bushing (nipple down), sway bar end, rubber bushing(nipple up), washer, spacer, washer, rubber bushing (this last bushing sits on washer welded to axle).
Now, underneath the axle where bolt comes out, finish like this: washer, rubber bushing, washer, nut.
Herez the challenge. That bolt is barely long enough for all of that. You have to squeeze everything together as hard as you can to start the nut a few turns. Now don't tighten it yet. Do the exact same thing on the other side.
6. Tighten step 5 down until you see about 1/8" of the bolt on the other side of nut. This seems to be the proper amount on my car. Don't forget to tighten step 4 too!
DONE!!!! After you drive it around a little, make sure and check everything is still nice and tight. If you look throught the rims, you can see the end of the bolt underneath the axle.
Attached Thumbnails Progress sway bar + perches review/picz-progress-01.jpg   Progress sway bar + perches review/picz-progress-02.jpg
reTro is offline
lixalot (Feb 20, 2024)
Old Apr 20, 2005, 02:03 PM
LancerEvoMR's Avatar
Discuss thread Here!
LancerEvoMR is offline
CanuckLancer
18
Apr 3, 2013 07:44 AM
Dan@Assaultech
Evo 'For Sale' Exterior Styling
157
Jul 12, 2010 02:15 PM
dyezak
66
May 14, 2010 11:36 AM
black cloud
Feb 13, 2009 03:18 AM
IA Performance
108
Jul 27, 2007 10:29 AM
Quick Reply: Progress sway bar + perches review/picz
